Instant 8.10.0.12 - what changed?
  • 1.  Instant 8.10.0.12 - what changed?
    Posted May 29, 2024 11:28 AM
    I have several sites where we have not fully refreshed all of our AP's from 335's up to the 535 model, and some that are 535 only.  Since we can't upgrade past 8.10.x.x (335's are not supported on any higher firmware version), I'm reviewing the release notes of newer versions and found that 8.10.0.12 has no resolved issues.  I also see:
    There are no new features, enhancements, or behavioral changes introduced in this release.
    I'm curious what was changed between versions to cause a minor release if there was nothing being fixed or added?
    https://www.arubanetworks.com/techdocs/Aruba-Instant-8.x-Books/Release-Notes/810/Aruba-Instant-8.10.0.12-Release-Notes.pdf
    Arubanetworks remove preview
    View this on Arubanetworks >
  • 2.  RE: Instant 8.10.0.12 - what changed?
    Posted May 29, 2024 06:24 PM
    8.10.0.12 was a fix on the controller side, but the controller and Instant code bases are kept in lock step so you've got an Instant release with no applicable changes.
    Carson Hulcher, ACEX#110
