Instant 8.3.0 replace certificates
  • 1.  Instant 8.3.0 replace certificates
    Posted Sep 18, 2018 02:41 PM
    I'm not able to replace the default Captive Portal certificate in an Aruba Instant environment with 2 AP-303's. The certificate worked succesful in my old AP-103 V6 environment.
    The certificate is imported with the GUI, with an succesfull responce. In the CLI system log an error appears:
    failed to parse cp cert
    After the import, the GUI is unavailable. WLAN clients still can connect and SSH is still possible. After a reboot of the AP's the GUI is working again, but the cp certificate is not available anymore:
    show cert
    Default Server Certificate:
    Version       :3
    Serial Number :B0:AF:C2:6A:09:93:85:18
    Issuer        :/C=US/ST=California/O=Aruba Networks/OU=Instant/CN=securelogin.arubanetworks.com
    Subject       :/C=US/ST=California/L=Sunnyvale/O=Aruba Networks/OU=Instant/CN=securelogin.arubanetworks.com
    Issued On     :Sep  9 04:58:42 2016 GMT
    Expires On    :Sep  8 04:58:42 2020 GMT
    Signed Using  :SHA256-RSA
    RSA Key size  :2048 bits
    Error in reading certificate file:
    Device Certificate:
    Version       :3
    Serial Number :1D:06:62:3E:00:02:00:49:43:8A
    Issuer        :/UID=com/UID=arubanetworks/UID=devicesign/CN=Aruba Networks Trusted Computing Issuing CA 1
    Subject       :/CN=CNFVK9T8H0::38:17:c3:c8:83:a4
    Issued On     :Apr 25 16:21:58 2018 GMT
    Expires On    :Sep 14 03:21:14 2032 GMT
    Also the captive portal is not working anymore. Only way to fix this is a factory reset and a config restore.
    Does anybody know how to fix this?
  • 2.  RE: Instant 8.3.0 replace certificates
    Posted Sep 19, 2018 10:01 AM
    Maybe you are running into the same problem as in this topic :
    https://community.arubanetworks.com/t5/Controllerless-Networks/Problems-replacing-certificate/m-p/466026
    Double check the procedure of creating the cert file.
  • 3.  RE: Instant 8.3.0 replace certificates
    Posted Sep 21, 2018 05:34 AM
    Hi Toys-toys,
    Double checked the procedure. Created a new CSR and certificate. Unfortunately with the same result.
  • 4.  RE: Instant 8.3.0 replace certificates
    Posted Oct 03, 2018 03:21 AM
    Today tried to replace the certificates in the CLI. No solution.
    AP-303_Slaapkamer# copy tftp 192.168.10.32 arubainstant_sneppie_nl.pem cpserver cert ******** format pem
    /bin/sh: 01: not found
    System log:
    Oct  3 08:59:55  cli[13678]: <341101> <WARN> |AP AP-303_Slaapkamer@192.168.10.41 cli|  Execute command-copy tftp 192.168.10.32 arubainstant_sneppie_nl.pem cpserver cert ************ format pem.
    Oct  3 08:59:57  cli[2686]: <341005> <ERRS> |AP AP-303_Slaapkamer@192.168.10.41 cli|  failed to parse cp cert
     Anybody any idea's?
