Instant 8.4.0 and supported models
  • 1.  Instant 8.4.0 and supported models
    Posted Jan 07, 2019 12:38 PM
    I see that the 8.4.0 releases notes show the supported hardware as:
    AP-303P,  AP-387 and the 510 Series — AP-514 and AP-515.
    Do you know how long it will be before the 8.4.0 code will be avaialable for the 340 series?
    Thank you,
  • 2.  RE: Instant 8.4.0 and supported models
    Posted Jan 07, 2019 12:46 PM
    I see the release notes here:  https://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/Command/Core_Download/Default.aspx?EntryId=32449
    I see the supported models in the chart here:
  • 3.  RE: Instant 8.4.0 and supported models
    Posted Jan 07, 2019 09:03 PM
    I have two 8.4.0 release note pdf files. One was unclear to me. The one file you got the screenshot from show only a few models. The second pdf shows many supported models with 8.4.0 but I assume that is for controller based since it doesn't specifically say "Instant".
    I have attached two for your review.
    Thank you,
    Attachment(s)
  • 4.  RE: Instant 8.4.0 and supported models
    Posted Jan 07, 2019 09:18 PM
    Both documents show and mention the AP-345.  Please let us know which part is not clear so that we can have it clarified.
  • 5.  RE: Instant 8.4.0 and supported models
    Posted Jan 15, 2019 03:15 PM
    Hi!
    I have three different IAP-Models in use: IAP-303, IAP-345 and IAP-365. The actual Firmware-Version is 8.3.0.5.
    When I search for a new Version automatically the message appears "no new Version available".
    When is the new Instant-Release 8.4.0.0 available?
    Many Thanks, Rene
  • 6.  RE: Instant 8.4.0 and supported models
  • 7.  RE: Instant 8.4.0 and supported models
    Posted Jan 16, 2019 01:35 AM
    Many Thanks!
