Instant Access points – Guest – internal Captive portal issue
  • 1.  Instant Access points – Guest – internal Captive portal issue
    Posted Jul 25, 2016 04:50 AM
    Firmware version:- 6.4.2.6-4.1.1.6_50009
    Model:- IAP 205
    Scenario:-
    • SSID “VISITOR”
    • DHCP server from Virtual controller assign.
    • Authentication server – Internal server from IAP.
    Issue:-
    I am not able to restrict the number of login  from particular Guest login account. Multiple login is enabled by default.
  • 2.  RE: Instant Access points – Guest – internal Captive portal issue
    Posted Jul 25, 2016 04:57 AM
    Please provide a screenshot of where you are restricting multiple logins.
  • 3.  RE: Instant Access points – Guest – internal Captive portal issue
    Posted Aug 04, 2016 12:50 AM
    Hi CJoseph,
    Actually i was going through features available for guest users in IAP. (Firmware is also upgraded to most recent version)
    I have tested below option which are helpful for guest authentication in IAP.
    • Internal (Editable) Captive portal for guest login.
    • Auto on/off Guest SSID.
    • Bandwidth limiting on particular SSID.
    • Guest session time out after disconnection from network (Guest users have to relogin in internal captive portal after approx. 3 minutes once disconnected from Guest Network )
    • Set maximum client limitation per SSID
    I could notice that one login account (Internal captive portal user login) can be access from more then one device simultaneously , which i want to limit.  Except that i found all other option very helpful in virtual controller(Normally requires hardware controller to achieve same).
