instant ACL size
  • 1.  instant ACL size
    Posted Feb 25, 2019 04:59 PM
    I have an installation of instant AP's running 6.5.3.3 and I want to put in a ACL that has 175 lines.  what is the maximum size of ACL's on this code and what is the best way to get the 175 line ACL into the ap ?
  • 2.  RE: instant ACL size
    Posted Feb 26, 2019 05:14 AM
    I don't know the exact ACL line limit on Aruba Instant, however, 175 ACLs in a single role doesn't sound good to me for maintainability reasons. It's probably a better design to simplify the ACLs and combine it with firewall rules on your firewall.
    In case you need more help, it's probably best to either work with your Aruba partner or local Aruba SE, or share more information on what you intend to achieve with this size of ACLs.
