Instant Airgroup Scalability Improvements?
  • 1.  Instant Airgroup Scalability Improvements?
    Posted Sep 25, 2020 09:45 AM
    We were on 6.5.3.3 instant and ran into scalability issues with Airgroup. The instant controller couldn't handle all the airgroup traffic, specifically for hundreds of Chromecasts so we had to purchase controllers after working with support onsite.
    The question is has the scalability changed since 6.5.3.3? We are planning on moving off the controllers to 8.6.0.6 because the controller licensing upgrades and renewals are just too much.
  • 2.  RE: Instant Airgroup Scalability Improvements?
    Posted Sep 26, 2020 08:23 PM
    if you are referring to the max Airgroup servers, then it is still 80 with instant 8.7.x as mentioned in the user guide.
