last person joined: 2 hours ago
Instant - Airwave connection via VPN Tunnel
  • 1.  Instant - Airwave connection via VPN Tunnel
    Posted Sep 09, 2014 05:33 AM
    Hi all,
    I'm wondering if it is possible to connect an IAP to Airwave using a VPN Tunnel that has been established to a central controller, and not via a direct internet link
    So, my setup is:
    Airwave is on a corporate VLAN (eg VLAN1), no direct internet access.
    IAP is connected on a branch site. Branch has a VLAN that is managed by the corporate wireless switch (central L2), VLAN is tunneled though the VPN tunnel (eg VLAN 14)
    In IAP I use the corporate VLAN1 IP address of the Airwaveserver.
    Is this a supported setup?
    Thanks and regards
