Instant AP-275
  • 1.  Instant AP-275
    Posted Apr 09, 2018 01:18 PM
    I`ve configured my stand alone IAP-275 using the WebUi pretty much with basic setup, i`ve created a SSID 5G that my camera connects to, to transfer the images to my computer via FTP, the max transfer speed of my wireless transmitter is 433.3Mbps over 80211-AC on channel 36 with client match selected, prefered connection is 5G.
    My question is, are there anymore more settings that I can choose to have a consistant thorough put of 433.3Mbps? its pretty fast, i like it, but I would like to see if there are anymore options that I can tweak in the virtual controller, please let me know.
    Kirk
  • 2.  RE: Instant AP-275
    Posted Apr 09, 2018 01:21 PM
    Do you have broadcast filtering enabled on that SSID?
  • 3.  RE: Instant AP-275
    Posted Apr 09, 2018 01:59 PM
    I Dont`t believe I do. however sir.
    Kirk
  • 4.  RE: Instant AP-275
    Posted Apr 09, 2018 02:03 PM
    After checking, Broadcast fitering is set to (ARP)
    Kirk
  • 5.  RE: Instant AP-275
    Posted Apr 09, 2018 09:25 PM
    That is probably the best thing you can do to improve performance.
  • 6.  RE: Instant AP-275
    Posted Apr 10, 2018 02:01 PM
    The performace is pretty good so far on 80211-AC. I running a few test on transferring large files i recorded 1 minute 4K video at 60frames-sec file size 6GB, it took 19mins to transfer at 351-433.3Mbps a sec, however I`ll be shooting images about 23-30MGs each it`s much faster than just send one large file considering its only one spatial stream.
    Kirk
  • 7.  RE: Instant AP-275
    Posted Apr 10, 2018 04:59 PM
    How far away are you from the access point?
    What type of client is this?
    Are you using encryption?
  • 8.  RE: Instant AP-275
    Posted Apr 10, 2018 05:36 PM
    at this point in my home test about 40ft, if yo go outside about 200ft or great data transfer isnt fast about 150-275 range as for images.
    Canon 1DX Mark II Camera, Canon wireless transmitter WFT-E8A
    I`m not sure how do I check?
    Kirk
  • 9.  RE: Instant AP-275
    Posted Apr 10, 2018 05:43 PM
    The further away you get, the worse performance will get, of course.
    Inside should have better performance than outdoors because of contention.
    That looks like good performance.
  • 10.  RE: Instant AP-275
    Posted Apr 10, 2018 06:08 PM
    Considering, I`m a motorsport photograher i wanted to use it in the field alteast 200ft away.
    also, its not elavated I`m working on finding a telescopic Mast to mount it on raise up about 20ft would that be sufficient?
    Kirk
  • 11.  RE: Instant AP-275
    Posted Apr 10, 2018 06:25 PM
    You are probably limited by the capabilities of the device that is connecting to that access point.  If it is a camera, where the specs are limited, you will be limited by the antenna design of the wifi connection of that camera...  The AP-275 might not be able to "hear" your camera better no matter how high it is mounted...
  • 12.  RE: Instant AP-275
    Posted Apr 17, 2018 08:50 PM
    thats something to consider.
    Kirk
