Instant AP
  • 1.  Instant AP
    Posted Nov 19, 2019 03:11 PM
    I want to add a new aruba ap to an existing aruba ap cluster using a static ip.
    What’s the steps?
  • 2.  RE: Instant AP
    Posted Nov 26, 2019 05:21 PM
    There are way too many unknowns in your question for us to answer effectively.
    If you've got DHCP, just connect the iAP, let it get a IP assigned and joing the cluster, then edit its configuration to set the static address and reboot it.
    If you haven't, then you would probably need to connect a console cable and assign the statis address by CLI.
