I'm new to Aruba wifi and Airwave and I'm currently deploying a 150 AP
Instant infrastructure on two campuses, so ZTP and Airwave is a big
concern for me. We are an Unix shop here, so we use ISC DHCP servers.
Aruba Instant documentation gives details only for Microsoft DHCP
server. This post is just to share the ISC DHCP server configuration
that has taken hours of fiddling for me ;-) .
In '/etc/dhcp/dhcpd.conf', nothing is needed at the global level.
At the subnet level, we have a group that shares common options for
the host declarations. Here we assign fixed IPv4 addresses according
to the MAC addresses, but YMMV.
# subnet WIFI-ADM-P
subnet 10.10.2.0 netmask 255.255.255.0 {
option routers 10.10.2.1;
group {
option domain-search "obspm.fr";
option domain-name-servers 10.10.10.21,10.10.10.24,10.10.20.21;
option ntp-servers ntp-p.obspm.fr, ntp-m.obspm.fr;
option domain-name "obspm.fr";
option vendor-class-identifier "ArubaInstantAP";
option vendor-encapsulated-options "Foo:Bar:Baz,10.10.10.74,yourpsk";
host ap-p-bperr-dio-coul-test-303-1.obspm.fr {
stash-agent-options true;
hardware ethernet b0:b8:67:ce:73:c6;
fixed-address 10.10.2.2;
option host-name "ap-p-test-303-1.obspm.fr";
host ap-p-bperr-dio-149-test-345-1.obspm.fr {
hardware ethernet 90:4c:81:c0:b8:ca;
fixed-address 10.10.2.3;
option host-name "ap-p-test-345-1.obspm.fr";
The important parts are:
The first one makes the server look for the option 60 (Vendor class
identifier) provided by the AP in a DHCP DISCOVER. For an Instant AP,
this is always "ArubaInstantAP".
The second one makes the server add an option 43 in its DHCP OFFER
with the specified content. The content is a three fields
comma-separated string, with no spaces in it. In this example:
- 'Foo:Bar:Baz': the colon-separated organisation string for e.g. the
folder hierarchy in Airwave: Foo → Bar → Baz - '10.10.10.74': the Airwave server IPv4 address (not tested with IPv6)
- 'yourpsk': the preshared key between the Instant Cluster and Airwave you chose
Having this two vendor DHCP options in a subnet scope permits to have
multiple vendor objects (e. g. IP phones and wifi AP) to peacefully
coexist in the same DHCP server configuration. Or two different
Instant clusters with different organisation strings.
Hope this will help you.
