Instant AP- IP address change
  • 1.  Instant AP- IP address change
    Posted Jun 25, 2013 03:36 AM
    Hi All,
    I would like to assign a static IP for instant APs  is that possible? I could not find the option to do so under the IAP configuration.
    Any help is much appreciated.
    Jay
  • 2.  RE: Instant AP- IP address change
    Posted Jun 25, 2013 06:12 AM
    You can do that by clicking on top of the MAC address of IAP (under Access point)once you do that you will be able to edit it and define wether you want it to have its ip using dhcp or statically
  • 3.  RE: Instant AP- IP address change
    Posted Jun 25, 2013 08:53 PM
    Thanks very much for the quick response.
    As I did not know the GUI method, I ended up  configuring from the CLI.
