Instant AP Mobility Domain WLAN access parameters.
  • 1.  Instant AP Mobility Domain WLAN access parameters.
    Posted Oct 14, 2014 10:46 AM
    Afternoon,
    In order for a client to roam within an Instant mobility domain, it is stated that the "WLAN access parameters" must be the same across the layer 3 networks. I understand the configuration of the mobility domain, which seems straightforward, however I would like confirmation of what is meant by identical WLAN access parameters.
    Does this refer to the SSID and its associated authentication method, meaning that a client can only roam at layer 3 if the same SSID and authentication are configured across the clusters/swarms in the mobility domain?
    Are there any other configurations that need to be consistant across clusters in the mobility domain?
    Johnny.
  • 2.  RE: Instant AP Mobility Domain WLAN access parameters.
    Posted Oct 14, 2014 12:00 PM
    You are on the right track:
    - You need the same SSID
    - Authentication type on the SSID
  • 3.  RE: Instant AP Mobility Domain WLAN access parameters.
    Posted Oct 14, 2014 12:29 PM
    Thanks Victor - what about 802.1X over a mobility domain? Is it possible to roam without re-authenticating?
    Johnny.
  • 4.  RE: Instant AP Mobility Domain WLAN access parameters.
    Posted Oct 14, 2014 01:31 PM
    Do you have OKC enabled ?
  • 5.  RE: Instant AP Mobility Domain WLAN access parameters.
    Posted Oct 16, 2014 08:50 AM
    For the sake of argument, lets say yes. In that case, would the pairwise key be shared with other L3 networks.
    Johnny.
  • 6.  RE: Instant AP Mobility Domain WLAN access parameters.
    Posted Oct 17, 2014 10:02 PM
    Yes
