Instant AP NBD Support and Aruba central subcription
  • 1.  Instant AP NBD Support and Aruba central subcription
    Posted Jan 14, 2016 03:19 PM
    It looks like or at least i understood that the support of the ap was included on the aruba central subcription
    is this included? or i still need to add the NBD SUPPORT FOR IAP ??
    Cheers
    Carlos
  • 2.  RE: Instant AP NBD Support and Aruba central subcription
    Posted Jan 14, 2016 06:07 PM
    Software support for the IAP is included in the Central subscription.
    Hardware support for the IAP is not included in the Central subscription.
    However, IAP hardware is covered by a different Limited Lifetime Warranty at no additional cost (http://www.arubanetworks.com/support-services/product-warranties/#HardwareLLW)
    If the customer requires next-business-day hardware replacements, only then do they need the NBD coverage.
    Hope his answers the question.
  • 3.  RE: Instant AP NBD Support and Aruba central subcription
    Posted Jan 14, 2016 06:50 PM
    So basically if i got a quote like this:
    IAP-205-RW
    SUB1-CNP-IAP-1
    i would have ArubaCare TAC + Software   right??? as the aruba subcription will give me that?
    I would not need in this case
    SN1-IAP-205-RW for ArubaCare TAC + Software?
    i am correct?
    I know ill only have limited liftime warranty in this case for HARDWARE
    ill only have Next Business-Day Shipment After Parts are Returned to Factory
    but not Next Business-Day Advanced Hardware Replacement
    I want to be clear with this as this will help us the clietn will havfe spare APS, but what they dont want to loose is the ArubaCare TAC + Software and i want to be sure
    cheers
    Carlos
  • 4.  RE: Instant AP NBD Support and Aruba central subcription
    Posted Jan 15, 2016 06:56 PM
    Carlos its probably best if you speak to your Aruba account rep and they can deep dive into with you.
