last person joined: 8 hours ago
Instant AP Sending either hostname OR username to ClearPass
  • 1.  Instant AP Sending either hostname OR username to ClearPass
    Posted Jan 20, 2015 05:21 PM
    Instant AP Cluster is sending either username or hostname for AAA on ClearPass.  Can we restrict the IAP cluster to only send the username, and CPPM to only accept the username authentication?
  • 2.  RE: Instant AP Sending either hostname OR username to ClearPass
    Posted Jan 20, 2015 05:35 PM
    What type of authentication are you using?
  • 3.  RE: Instant AP Sending either hostname OR username to ClearPass
    Posted Jan 20, 2015 05:37 PM
    OnBoard, so first EAP-PEAP, then EAP-TLS.  Sometimes a user authenticates with one (machine or user), then it will send the other, failing and starting the process again.
  • 4.  RE: Instant AP Sending either hostname OR username to ClearPass
    Posted Jan 20, 2015 05:39 PM
    The reflected username will be dependent on how the device is
    authenticating.
    If it machine authenticates, it will show the FQHN. If the user
    authenticates, it will show the username.
    If you want the device to only machine authenticate, you need to configure
    the clients manually, use group policy, or use something like quickconnect.
    Are you Onboarding personal or corporate devices?
  • 5.  RE: Instant AP Sending either hostname OR username to ClearPass
    Posted Jan 20, 2015 05:46 PM
    OnBoard with both corporate and personal devices.
    I have also enabled MAC Fail-through as a possibility as well, both not "Enforce MAC Auth".
  • 6.  RE: Instant AP Sending either hostname OR username to ClearPass
    Posted Jan 20, 2015 05:55 PM
    The clients would need to be configured for user authentication or you would
    have to use dual-SSID onboard.
