Instant APs cannot be converted to Campus APs and then terminate to a Controller
  • 1.  Instant APs cannot be converted to Campus APs and then terminate to a Controller
    Posted Mar 17, 2012 07:01 AM
    Hello All,
    We have a 105AP running the Code of an Instant AP. I have tried all possible ways to convert this AP to a Campus AP (CAP) to no avail.
    It simply just comes up as an Instant AP.
    I even set the Instant AP to factory default and still.
    Even after setting it to factory default, I connected it to a Physical Port on the 620 Controller. It still came up as an Instant.
    Can Instant APs be really converted to Caps?
  • 2.  RE: Instant APs cannot be converted to Campus APs and then terminate to a Controller
    Posted Mar 17, 2012 07:04 AM
    You have to go under Maintenence> Convert to point it to an active controller to convert.
  • 3.  RE: Instant APs cannot be converted to Campus APs and then terminate to a Controller
    Posted Mar 17, 2012 07:05 AM
    Yep! Tried that over 5 times and still could not get it to convert to a CAP.
  • 4.  RE: Instant APs cannot be converted to Campus APs and then terminate to a Controller
    Posted Mar 17, 2012 07:07 AM
    What version of code is on the controller?
  • 5.  RE: Instant APs cannot be converted to Campus APs and then terminate to a Controller
    Posted Mar 17, 2012 07:09 AM
    6.0.1.0
  • 6.  RE: Instant APs cannot be converted to Campus APs and then terminate to a Controller
    Posted Mar 17, 2012 07:14 AM
    Unfortunately, you need a minimum of ArubaOS 6.1 on the controller to convert the APS.
  • 7.  RE: Instant APs cannot be converted to Campus APs and then terminate to a Controller
    Posted Mar 17, 2012 07:17 AM
    **bleep**! Oh well.
    I always knew we might need to upgrade at sometime.
    Is there a link or documentation where I can reference this?
  • 8.  RE: Instant APs cannot be converted to Campus APs and then terminate to a Controller
    Posted Mar 17, 2012 07:19 AM
    We are trying to get it added as we speak.  Please see the thread right here:  http://community.arubanetworks.com/t5/Access-Points/Converting-IAP-105-to-an-AP-105/m-p/14594/highlight/true#M2054
  • 9.  RE: Instant APs cannot be converted to Campus APs and then terminate to a Controller
    Posted Mar 17, 2012 07:26 AM
    Thanks Joseph.
    Will try that out and keep you updated.
  • 10.  RE: Instant APs cannot be converted to Campus APs and then terminate to a Controller
    Posted Mar 17, 2012 07:15 AM
    Do you think the Software Version on the 620 Controller could be the issue?
