Instant APs not being seen by controller
  • 1.  Instant APs not being seen by controller
    Posted Sep 22, 2014 04:10 PM
    We had a power outage last week. Somehow it message with the Aruba PoE switch we had, and most likely the wireless controller as well. We performed several troubleshooting tasks, but eventually just had to wipe out the conifguration on the switch. Another tech rebuilt the configuration and we now have Internet access if you are plugged in with a cable. However, the Aruba 105 IAPs are not broadcasting SSIDs now and the controller can't find them. I am sure it has something to do with the fact that the switch the controller is connected to has been re-configured, but it should have almost identitical properties as before (same VLANs, etc.).
    Here's what I have:
    Aruba S3500-24P PoE switch
    Aruba 650 wireless controller.
    The address of the controller from the documentation I have is 10.116.0.5. I cannot ping that even if I am connected directly to the ports on the controller. When I am plugged in with a UTP cable, I get a DHCP IP address of 10.116.13.XXX, so I know there is communication happening between the controller and the switch somehow. The IAPs are also showing IP addresses on the same network. The only way to access the web interface of the controller is to set a static IP address on the same network (10.116.0.XX).
    I am very new to Aruba products, but it feels somewhat similar to Cisco, so I can feel my way around a little bit.
    Anyway, I plugged into an AP's console port and here is the output (Any names with XXX... is to provide at least some anonymity to the network):
    APBoot 1.0.9.12 (build 22797)
    Built: 2009-11-04 at 15:53:54
    Model: AP-10x
    CPU:   AR7161 revision: A2
    Clock: 680 MHz, DDR clock: 340 MHz, Bus clock: 170 MHz
    DRAM:  128 MB
    POST1: passed
    Copy:  done
    Flash: 16 MB
    PCI:   scanning bus 0 ...
           dev fn venID devID class  rev    MBAR0    MBAR1    MBAR2    MBAR3
           00  00  168c  0029 00002   01 10000000 00000000 00000000 00000000
           01  00  168c  0029 00002   01 10010000 00000000 00000000 00000000
    Net:   eth0
    Radio: ar922x#0, ar922x#1
    Hit <Enter> to stop autoboot:  0
    Checking image @ 0xbf100000
    Image is signed; verifying checksum... passed
    Signer Cert OK
    Policy Cert OK
    RSA signature verified.
    ELF file is 32 bit
    Loading .text @ 0x80e00000 (3768408 bytes)
    Loading .data @ 0x81198060 (32 bytes)
    Clearing .bss @ 0x81198080 (16 bytes)
    ## Starting application at 0x80e00000 ...
    Uncompressing...................................
    ú
    Aruba Networks
    ArubaOS Version 6.1.3.4-AirGroup (build 35647 / label #35647)
    Built by p4build@stan on 2012-10-08 at 12:50:26 PDT (gcc version 4.3.3)
    CPU Rev: aa
    71x CPU
    Flash variant: default
    Cache parity protection disabled
    Using 340.000 MHz high precision timer. cycles_per_jiffy=680000
    Memory: 122880k/131072k available (1850k kernel code, 8088k reserved, 681k data, 2952k init, 0k highmem)
    detected lzma initramfs
    initramfs: LZMA lc=3,lp=0,pb=2,dictSize=8388608,origSize=12341760
    LZMA initramfs by Ming-Ching Tiew <mctiew@yahoo.com> .............................................................................................................................................................................................
    AR7100 GPIOC major 0
    wdt: registered with refresh
    Enabling Watchdog
    Talisker RSSI LED initialization
    Creating 1 MTD partitions on "ar7100-nor0":
    0x00000000-0x01000000 : "flash"
    i2c /dev entries driver
    i2c-talisker: using default base 0x18040000
    AD7416 driver probing for devices on AR7100 I2C
    .<6>lo: Disabled Privacy Extensions
    IPv6 over IPv4 tunneling driver
    Starting Kernel SHA1 KAT ...Completed Kernel SHA1 KAT
    Starting Kernel HMAC-SHA1 KAT ...Completed Kernel HMAC-SHA1 KAT
    Starting Kernel DES KAT ...Completed Kernel DES KAT
    Starting Kernel AES KAT ...Completed Kernel AES KAT
    Domain Name: arubanetworks.com
    No panic info available
    Testing TPM... Passed
    ag7100_mod: module license 'unspecified' taints kernel.
    AG7100: Length per segment 512
    AG7100: Max segments per packet 4
    AG7100: Max tx descriptor count    400
    AG7100: Max rx descriptor count    252
    AG7100: fifo cfg 3 018001ff
    AG7100CHH: Mac address for unit 0
    AG7100CHH: d8:c7:c8:c2:69:1a
    ATHRF1: Port 0, Neg Success
    ATHRF1: unit 0 phy addr 0 ATHRF1: reg0 0
    AP xml model 39, num_radios 2 (jiffies 4153)
    init_asap_mod: installation:0
    radio 0: band 1 ant 0 max_ssid 8
    radio 1: band 0 ant 0 max_ssid 8
    setting bond0 as bridge child
    setting gre0 as split child
    Starting watchdog process...
    Getting an IP address...
    ag7100_ring_alloc Allocated 4800 at 0x813b0000
    ag7100_ring_alloc Allocated 3024 at 0x813a6000
    AG7100: cfg1 0xf cfg2 0x7014
    ATHRF1: unit 0 phy addr 0 ATHRF1: reg0 3100
    AG7100: unit 0: phy not up carrier 1
    Writing 4
    ADDRCONF(NETDEV_UP): bond0: link is not ready
    AG7100: unit 0 phy is up...RGMii 1000Mbps full duplex
    AG7100: pll reg 0x18050010: 0x110000  AG7100: cfg_1: 0x1ff0000
    AG7100: cfg_2: 0x3ff
    AG7100: cfg_3: 0x18001ff
    AG7100: cfg_4: 0xffff
    AG7100: cfg_5: 0xfffef
    AG7100: done cfg2 0x7215 ifctl 0x0 miictrl 0x22
    ADDRCONF(NETDEV_CHANGE): bond0: link becomes ready
    10.116.13.7 255.255.248.0 10.116.8.1
    Running ADP...cat: /tmp/master: No such file or directory
    Done. Master is
    killall: nanny: no process killed
    killall: sapd: no process killed
    Sending SIGKILL to all processes.
    Please stand by while rebooting the system.
    ___________________________________________________________________
    Here are some lines from the "Show run..." command on the controller:
    vlan range 2 wired aaa-profile "XXXX-aaa_prof"
    vlan 3 wired aaa-profile "XXXX-WEP-aaa_prof"
    vlan 4 wired aaa-profile "XXXXGuest-aaa_prof"
    vlan-name XXXX-Trusted pool
    vlan XXXX-Trusted 2-3
    vlan-name XXXX-Untrusted pool
    vlan XXXX-Untrusted 4
    interface gigabitethernet 1/0
    description "GE1/0"
    trusted
    trusted vlan 1-4094
    interface gigabitethernet 1/1
    description "GE1/1"
    trusted
    trusted vlan 1-4094
    interface gigabitethernet 1/2
    description "GE1/2"
    trusted
    trusted vlan 1-4094
    interface gigabitethernet 1/3
    description "GE1/3"
    trusted
    trusted vlan 1-4094
    interface gigabitethernet 1/4
    description "GE1/4"
    trusted
    trusted vlan 1-4094
    interface gigabitethernet 1/5
    description "GE1/5"
    trusted
    trusted vlan 1-4094
    switchport mode trunk
    interface gigabitethernet 1/6
    description "GE1/6"
    trusted
    trusted vlan 1-4094
    interface gigabitethernet 1/7
    description "GE1/7"
    trusted
    trusted vlan 1-4094
    interface vlan 1
    ip address 10.116.0.5 255.255.255.0
    ip default-gateway 10.116.8.1
    no uplink wired vlan 1
    uplink disable
    ip dhcp excluded-address 192.168.99.1 192.168.99.10
    ip dhcp excluded-address 192.168.98.1 192.168.98.10
    ip dhcp excluded-address 192.168.97.1 192.168.97.10
    ip dhcp excluded-address 192.168.96.1 192.168.96.10
    ip dhcp excluded-address 192.168.96.253 192.168.96.254
    ip dhcp pool DHCP-999
    default-router 192.168.99.1
    dns-server 10.116.12.41 10.116.12.49
    domain-name XXXXXXX
    lease 0 8 0 0
    network 192.168.99.0 255.255.255.0
    authoritative
    ip dhcp pool DHCP-998
    default-router 192.168.98.1
    domain-name XXXXXXX
    lease 0 8 0 0
    network 192.168.98.0 255.255.255.0
    authoritative
    ip dhcp pool DHCP-997
    default-router 192.168.97.1
    dns-server 4.2.2.1 4.2.2.2
    lease 0 4 0 0
    network 192.168.97.0 255.255.255.0
    authoritative
    ip dhcp pool DHCP-996
    default-router 192.168.96.1
    lease 0 4 0 0
    network 192.168.96.0 255.255.255.0
    authoritative
    service dhcp
    ____________________________________________________________________
    Now from the switch:
    ip-profile
    default-gateway 10.115.0.161
    controller-ip vlan 1
    lcd-menu
    interface-profile ospf-profile "default"
    area 0.0.0.0
    interface-profile pim-profile "default"
    interface-profile igmp-profile "default"
    stack-profile
    ipv6-profile
    interface-profile switching-profile "default"
    interface-profile switching-profile "XXXXUpstream"
    access-vlan 6
    native-vlan 6
    interface-profile switching-profile "Trunk"
    switchport-mode trunk
    access-vlan 10
    native-vlan 10
    interface-profile switching-profile "Upstream-profile"
    access-vlan 10
    native-vlan 10
    interface-profile switching-profile "VLAN10"
    access-vlan 10
    native-vlan 10
    interface-profile poe-profile "default"
    interface-profile poe-profile "poe-factory-initial"
    enable
    interface-profile enet-link-profile "default"
    interface-profile lldp-profile "default"
    interface-profile lldp-profile "lldp-factory-initial"
    lldp transmit
    lldp receive
    med enable
    interface-profile mstp-profile "default"
    interface-profile pvst-port-profile "default"
    vlan-profile mld-snooping-profile "default"
    vlan-profile igmp-snooping-profile "default"
    vlan-profile igmp-snooping-profile "igmp-snooping-factory-initial"
    spanning-tree
    mode mstp
    gvrp
    mstp
    lacp
    vlan "1"
    vlan "6"
    description "VLAN0006"
    vlan "10"
    description "VLAN0010"
    vlan "20"
    description "VLAN0020"
    interface gigabitethernet "0/0/0"
    interface gigabitethernet "0/0/1"
    interface gigabitethernet "0/0/2"
    interface gigabitethernet "0/0/3"
    interface gigabitethernet "0/0/4"
    interface gigabitethernet "0/0/5"
    interface gigabitethernet "0/0/6"
    interface gigabitethernet "0/0/7"
    interface gigabitethernet "0/0/8"
    interface gigabitethernet "0/0/9"
    interface gigabitethernet "0/0/10"
    interface gigabitethernet "0/0/11"
    interface gigabitethernet "0/0/12"
    interface gigabitethernet "0/0/13"
    interface gigabitethernet "0/0/14"
    interface gigabitethernet "0/0/15"
    interface gigabitethernet "0/0/16"
    interface gigabitethernet "0/0/17"
    interface gigabitethernet "0/0/18"
    interface gigabitethernet "0/0/19"
    interface gigabitethernet "0/0/20"
    interface gigabitethernet "0/0/21"
    interface gigabitethernet "0/0/22"
    interface gigabitethernet "0/0/23"
    interface vlan "1"
    ip address 10.116.0.1 255.255.255.0
    interface vlan "10"
    ip address 10.116.8.1 255.255.248.0
    interface vlan "20"
    ip address 10.116.16.1 255.255.248.0
    interface vlan "6"
    ip address 10.115.0.162 255.255.255.252
    interface mgmt
    interface-group gigabitethernet "default"
    apply-to ALL
    _______________________________________________________________________
    Hopefully there is some useful information in there. Any ideas to help get me started?
  • 2.  RE: Instant APs not being seen by controller
    Posted Sep 23, 2014 08:28 AM
    TAC is probably your best bet, because they can troubleshoot this live.  There is information missing that TAC can probably obtain on a call to determine what is wrong here.
