Network Management
Instant automatic configuration with Airwave
  • 1.  Instant automatic configuration with Airwave
    Posted May 18, 2015 09:07 AM
    i have my DHCP scope setup with option 43 and 60. the new APs find the AirWave server and receive their golden config.
    but when i then access the IAP via the GUI im asked to configure a country code, which fails as the AP is management by AirWave. is this normal behaviour? i would expect the IAP to already receive this from the AirWave.
  • 2.  RE: Instant automatic configuration with Airwave
    Posted May 18, 2015 01:19 PM
    What version of AirWave and Instant firmware?  If you can provide the details, we can have a team member replay the same combination in the lab.
  • 3.  RE: Instant automatic configuration with Airwave
    Posted May 18, 2015 01:25 PM
    thanks Rob
    Airwave: 8.0.7.1
    Instant: 6.3.1.4-4.0.0.6_44126
    if you believe a later version will work differently i can try that also.
  • 4.  RE: Instant automatic configuration with Airwave
    Posted May 18, 2015 09:29 PM
    if use template, please check if template missing a line such as:
    version 6.4.2.0-4.1.1
    virtual-controller-country CA
    if you need to know the code, please let me know the country you wanna select.
    if use IGC, please enbale [allow configuration of airwave settings] in Airwave->Airwave Setting,
    then select country under System->General page.
  • 5.  RE: Instant automatic configuration with Airwave
    Posted May 19, 2015 05:00 AM
    ah Airwave Config setting, missed those. thanks wdeng.
    should i enable [Allow Configuration Of Airwave Settings]? shouldn't i enable [Allow Configuration Of Country Code] ? because with the first option i would assume it also overwrites the org string which i don't want to.
  • 6.  RE: Instant automatic configuration with Airwave
    Posted May 19, 2015 05:21 AM
    my mistake, should enable [Allow Configuration Of Country Code]
  • 7.  RE: Instant automatic configuration with Airwave
    Posted May 19, 2015 01:48 PM
    not a problem, that did indeed the trick, thank you.
