instant client name ?????
  • 1.  instant client name ?????
    Posted Aug 17, 2017 03:52 PM
    Hi everyone
    I have a deployment with several IAPs clusters with airwave, all work fine but some username of clients is showing like "?????".
    The SSID is with 802.1x and just are few client that have that issue.
    in addition the client is authenticated, with IP
    Do you know the reason?, why that client don´t show the real username? the client put the correct credential
    I attach a picture.
    Thank
  • 2.  RE: instant client name ?????
    Posted Aug 17, 2017 03:57 PM
    Does the username show in the Instant GUI?
  • 3.  RE: instant client name ?????
    Posted Aug 17, 2017 04:01 PM
    in the instant gui and the airwave gui
  • 4.  RE: instant client name ?????
    Posted Aug 17, 2017 04:03 PM
    Look in the radius server logs and see if it is returning the username to instant. The other thought is that the client has an anonymous username configured. Is this happening to all or just some clients? Has this ever worked?
  • 5.  RE: instant client name ?????
    Posted Aug 17, 2017 04:06 PM
    Is happening with a few client
    thank
  • 6.  RE: instant client name ?????
    Posted Aug 17, 2017 04:16 PM
    Try getting one of those clients and see if they have an anonymous user configured in the 802.1x supplicant.  Either that or configure your own 802.1x client with an anonymous user to see if that is the issue.
  • 7.  RE: instant client name ?????
    Posted Aug 17, 2017 05:32 PM
    I did my own ssid with 802.1x authentication and when i connected without anonymus name the connection was successfully, but when i did put a anonymus name the connection was unsuccessfully
    PEAP
    MSCHAPV2
    anonymus (clean)
    username
    pass
    with this config my suplicant was successful
    PEAP
    MSCHAPV2
    anonymus (xxxxx)
    username
    pass
    with this config in my suplicant the connection was unsuccessfully
    and in the instant GUI and airwave the username was the correct.
  • 8.  RE: instant client name ?????
    Posted Aug 17, 2017 05:58 PM
    What radius server?
  • 9.  RE: instant client name ?????
    Posted Aug 18, 2017 08:24 AM
    it is a window radius (window server 2012)
  • 10.  RE: instant client name ?????
    Posted Aug 18, 2017 10:37 AM
    You should open a TAC case.  I have never seen that before...
  • 11.  RE: instant client name ?????
    in the instant and airwave GUI is showing with ????
