INSTANT CONVERT TO CAP
  • 1.  INSTANT CONVERT TO CAP
    Posted Apr 03, 2013 02:48 PM
    CAN I CONVERTE INSTANT 6.1.3 VERSTION TO CAP ON MOBILITY CONTROLLER RUNNING 5.0.3 VERSION?
  • 2.  RE: INSTANT CONVERT TO CAP
    Posted Apr 03, 2013 03:03 PM
    i tried two IAP105 converto to CAP and i cant this is the log i have... can somebody help me
    Target : 6c:f3:7f:ca:ca:b9 show vpn status vpn primary external ip :0.0.0.0 vpn primary tunnel ip :0.0.0.0 vpn backup external ip :0.0.0.0 vpn backup tunnel ip :0.0.0.0 vpn current used external ip :0.0.0.0 vpn current remote tunnel ip :0.0.0.0 vpn current ap's tunnel ip :0.0.0.0 vpn is preempt status :False vpn hold down period :600 vpn status :down vpn primary external ip :0.0.0.0 vpn primary tunnel ip :0.0.0.0 vpn backup external ip :0.0.0.0 vpn backup tunnel ip :0.0.0.0 vpn current used external ip :0.0.0.0 vpn current remote tunnel ip :0.0.0.0 vpn current ap's tunnel ip :0.0.0.0 vpn is preempt status :False vpn hold down period :600 vpn status :down end of show vpn status ======================================================== show upgrade info Image Upgrade Progress ---------------------- Mac IP Adress AP Class Status Image Info Error Detail --- --------- -------- ------ ---------- ------------ 6c:f3:7f:ca:ca:b9 10.41.6.209 Orion downloading ac-ftp://10.41.6.11/mips32.ari Image verify fail end of show upgrade info ======================================================== show log upgrade ----------Download log start---------- Executing '/aruba/bin/download_image_swarm ac-ftp://10.41.6.11/mips32.ari' fetching ('/usr/sbin/wget -T 120 -t 3 ftp://sap:x@10.41.6.11/mips32.ari') cleaning up done ----------Download log end------------ Download status: Image verify fail ----------Upgrade log start---------- upgrade log not available ----------Upgrade log end------------ Upgrade status: upgrade status not available end of show log upgrade ======================================================== show log rapper Rapper info not available end of show log rapper ========================================================
  • 3.  RE: INSTANT CONVERT TO CAP
    Posted Apr 03, 2013 04:04 PM
    Sorry,No you cant. :smileysad:
    In order to convert iAP-105 to CAP your controller must have higher arubaos version. :smileysurprised:
    From the release note:
    An IAP can be converted to an ArubaOS Campus AP only if the controller is running ArubaOS 6.1 or later and to an
    ArubaOS Remote AP only if the controller is running ArubaOS 6.1.4 or later.
    hope that info helped u. :smileyhappy:
    me
  • 4.  RE: INSTANT CONVERT TO CAP
    Posted Apr 17, 2013 02:34 AM
    Nice info Asa,
    Keep it up
