Instant CP using External Radius Server
  • 1.  Instant CP using External Radius Server
    Posted Aug 24, 2015 11:07 PM
    HI
    I using IAP 135 with Version: 6.4.0.3-4.1.0.1_45063
    I have created two SSID one is using WPA2-Enterprise and other is CP using the same external radius server + local database.
    I can successfully connect to WPA2-Enterprise SSID, but fail to use the same account in the CP.
    can anyone help?
  • 2.  RE: Instant CP using External Radius Server
    Posted Aug 24, 2015 11:17 PM
    How can something be using an external radius server and the internal database at the same time?  How does that work?
  • 3.  RE: Instant CP using External Radius Server
    Posted Aug 24, 2015 11:48 PM
    Can I do that in order to have back up server?
    anyway, I have success to login the CP with the Radius account, but I cannot use Internal database for backup, and I need to do some config in Windows NPS .InstantCP.PNG
  • 4.  RE: Instant CP using External Radius Server
    Posted Aug 25, 2015 08:01 AM
    im missing a bit of a question in your last post.
    you did create the user in the internal database? how did you test it didn't work?
    using the internal database as a backup for the external radius doesn't feel like a very solid solution. it means you have to create user double.
  • 5.  RE: Instant CP using External Radius Server
    Posted Sep 01, 2015 03:16 AM
    Actually, I want some guest account store in Radius Server and some guest account store in local database for some reason, so I need two auth server (Radius+local DB) to do that, is that possible?
  • 6.  RE: Instant CP using External Radius Server
    Posted Sep 01, 2015 01:05 PM
    that depends if you can do a fall through on instant, so that if the first source fails with a deny it tries the next. you should be able to check for that on the GUI. if there isn't something like that and it is meant to prevent a server outage it won't work.
