last person joined: 7 hours ago
Instant & CPPM - CPGuest Portal not sending radius request to CPPM
  • 1.  Instant & CPPM - CPGuest Portal not sending radius request to CPPM
    Posted Mar 27, 2019 09:29 AM
    Hello there,
    I am facing a strange issue since I changed the certificates on my Instant VC and my CPG portal.
    All was working before.
    When a user is registered and enabled from SR portal, he is getting a register loop.
    On CPPM, there isn't log in the Access Tracker.
    I am using :
    - Self Registration portal from CP Guest
    - User authentication with mac caching policies on CPPM
    - Instant VC running 6.5.4.12 with 205 and 305 IAPs
    Here's my Instant configuration :
    name ctl.portail-guest.com
    dynamic-radius-proxy
    mas-integration
    extended-ssid
    wlan access-rule Guests
     index 5
     rule 10.33.10.230 255.255.255.255 match any any any permit
     rule 10.33.0.0 255.255.0.0 match any any any deny
     rule any any match any any any permit
    wlan access-rule role_preauth_guest
     index 7
      captive-portal external profile www.portail-guest.com
     rule 10.33.10.230 255.255.255.255 match tcp 443 443 permit
     rule 10.33.10.230 255.255.255.255 match tcp 80 80 permit
     rule 8.8.8.8 255.255.255.255 match udp 53 53 permit
     rule 8.8.4.4 255.255.255.255 match udp 53 53 permit
     rule alias www.portail-guest.com match tcp 80 80 permit
     rule alias www.portail-guest.com match tcp 443 443 permit
     rule alias ctl.portail-guest.com match tcp 443 443 permit
     rule alias ctl.portail-guest.com match tcp 80 80 permit
     rule masterip 0.0.0.0 match tcp 80 80 permit
     rule masterip 0.0.0.0 match tcp 443 443 permit
     rule apnetwork 0.0.0.0 match tcp 80 80 permit
     rule apnetwork 0.0.0.0 match tcp 443 443 permit
     rule any any match any any any deny
    wlan ssid-profile Guests
     enable
     index 3
     type guest
     essid Guests
     opmode opensystem
     max-authentication-failures 0
     vlan 60
     auth-server CPPM
     set-role-pre-auth role_preauth_guest
     rf-band all
     dtim-period 1
     broadcast-filter arp
     dmo-channel-utilization-threshold 90
     local-probe-req-thresh 0
     max-clients-threshold 64
    wlan auth-server CPPM
     ip 10.33.10.230
     port 1812
     acctport 1813
     timeout 30
     key a14b790a22d3b7fe53b6bdc8b06e8979dd305b0cf5bd3855
     nas-ip 10.200.0.230
     nas-id ctl.portail-guest.com
     rfc3576
     cppm-rfc3576-port 5999
     service-type-framed-user 1x
     service-type-framed-user cp
    wlan external-captive-portal www.portail-guest.com
     server www.portail-guest.com
     port 80
     url "/guest/inscription_guest.php"
     auth-text ""
     redirect-url "http://www.google.fr"
     auto-whitelist-disable
    Any ideas why my VC is not sending Radius auth request when my client device is redirected after successful registering?
    And I don't understand why it has stoped running after changing SSL certificates...
    Many thanks
  • 2.  RE: Instant & CPPM - CPGuest Portal not sending radius request to CPPM
    Posted Mar 27, 2019 02:08 PM
    Did you change just the certificate or the hostname too of the controller?
    I would check few things below first:
    1. Is the client able to resolve the hostname of the controller? Nslookup etc.
    2. When you enter the credentails and click on login on the client, what is the url that it trying to post the credentials to?
    3. pcap from the client machine, would show, if the client is able to post the credentials or not, and failing?
    4. If the client is not able to post the credentails and failing, we need to look at the acl's.
    you mentioned it was working before and stopped working after you updating the certificate? did the CN name changed on the certificate? if yes, we need to update the CN name on the Clearpass Guest configuration, under NAS vendor settings.
  • 3.  RE: Instant & CPPM - CPGuest Portal not sending radius request to CPPM
    Posted Mar 28, 2019 09:42 AM
    Many thanks for sharing your findings.
    I finallly resolved the issue :
    I changed the previous signed SSL certificate with a wildcard certificate.
    I needed to change the CN name on the Guest NAS vendor settings to captiveportal-login.mydomain.com.
    All is working fine now.
    I am a little bit confused about certificate configuration with Instant APs... Is there any guide mentioning certificate import and wildcard certificate specific process ?
  • 4.  RE: Instant & CPPM - CPGuest Portal not sending radius request to CPPM
    Posted Mar 28, 2019 02:32 PM
    Hello Jeremy,
    Great news, I am glad that i was helpful for you. I would recommend looking at aruba instant user guide and also this article, should also be explaining about installing cert on IAP:
    https://community.arubanetworks.com/t5/Controller-less-WLANs/How-to-Create-a-Certificate-for-Instant-Captive-Portal-using/ta-p/277025
