Instant DHCP Helper
  • 1.  Instant DHCP Helper
    Posted Sep 15, 2015 06:32 PM
    I want to setup my Instant controllers to send dhcp (IP Helper) requests to Clearpass. I know how to setup an ip helper replay on controllers but not instant. Anyone?
  • 2.  RE: Instant DHCP Helper
    Posted Sep 15, 2015 07:02 PM
    http://community.arubanetworks.com/t5/Aruba-Instant-Cloud-Wi-Fi/Can-IAP-serv
    e-DHCP-and-relay-DHCP-requests-to-ClearPass-for/td-p/167936
  • 3.  RE: Instant DHCP Helper
    Under dhcp create a centralized layer 2 dhcp for the VLAN and then configure the dhcp relay
  • 4.  RE: Instant DHCP Helper
    Posted Mar 03, 2016 07:26 AM
     Dear Support,
    Can you please tell me exactly where we have to mention clearpass server ip address as dhcp helper address on IAP to know endpoint device information on clearpass to apply vlan enforcements through clearpass base on device type. e.g smart device will get x vlan where windows device get y vlan.
    Regard's
    Prasad Masurkar
  • 5.  RE: Instant DHCP Helper
    Posted Mar 03, 2016 08:48 AM
    The default gateway of the clients needs to have a helper address pointing to the clearpass server.
  • 6.  RE: Instant DHCP Helper
    Posted Mar 03, 2016 12:18 PM
    ?Dear Support,
    Can you please explain exactly how default gateway of the client have helper address pointing to clearpass server.
    Regard's
    Prasad
  • 7.  RE: Instant DHCP Helper
    Posted Mar 03, 2016 12:20 PM
    Thanks for update but can you please tell me how we can pointer clearpass server ip as helper address for client default gateway.
  • 8.  RE: Instant DHCP Helper
    Posted Mar 03, 2016 12:32 PM
    What is the default gateway if your clients?  Is it a router?
  • 9.  RE: Instant DHCP Helper
    Posted Mar 04, 2016 12:18 AM
    default gateway is configured on core switch and dhcp scope configured on windows server
  • 10.  RE: Instant DHCP Helper
    Posted Mar 04, 2016 07:50 AM
    Are the clients and the DHCP server on the same VLAN?
  • 11.  RE: Instant DHCP Helper
    Posted Mar 04, 2016 08:13 AM
    no
    #AirheadsMobile
  • 12.  RE: Instant DHCP Helper
    Posted Mar 04, 2016 08:24 AM
    So how is client DHCP traffic forwarded to a different subnet?
  • 13.  RE: Instant DHCP Helper
    Posted Mar 08, 2016 12:10 PM
    vlan ip assign on core switch where dhcp helper address assign to get vlan ip on client system
    #AirheadsMobile
