Instant - disable DFS timeout?
  • 1.  Instant - disable DFS timeout?
    Posted Jun 07, 2013 05:42 AM
    Hi everyone,
    I've noticed that 5GHz SSID comes up 10 minutes after AP is up due to DFS. This is pretty painfull with Survey AP which is turn on/off very often.
    Is there a woraround for this?
    V.D.
  • 2.  RE: Instant - disable DFS timeout?
    Posted Jun 07, 2013 09:39 AM
    You probably done this , but have you tried turning DFS off ?
    And how were you able to determine that it was getting turned off because of DFS ?
  • 3.  RE: Instant - disable DFS timeout?
    Posted Jun 07, 2013 09:55 AM
    Read my thread here, http://community.arubanetworks.com/t5/Access-Points/Change-channel-on-AP105-RAP-used-for-survey/m-p/15104
    Set the channel to one of the non-dfs channels.  Unfortunately you need to do this every time it powers on, which may not be practical, so try to have a battery pack you can carry around with the AP.  Bear in mind, I found that this only lasts for about two hours and then you have to do it again.
    Alternatively when you provision the RAP, put it into a group where the channel is fixed and ARM/scanning is disabled.
    Hope that helps.
    :smileyhappy:
  • 4.  RE: Instant - disable DFS timeout?
    Posted Jun 10, 2013 03:54 AM
    Michael_Clarke : OK that makes sense, I'll try it with non-DFS channel and scanning disabled.
    Thanks!
