INSTANT Does not change channel
  • 1.  INSTANT Does not change channel
    Posted Sep 02, 2016 06:44 AM
    Hi everbody, i start work with aruba and have been a good experience, at least until now.
    I heve 40 AP 224 and one as controler, i remotely access information by Instant version   6.4.4.8-4.2.4.1_55602.
    But after a try to change manually the channel of 2,4 ghz and 5 ghz, it does not change.
    If i change to auto, it changes but in manual it keep the same with no error message.
    I have to reboot all AP to my changes apply in all access points?
    Its some sort of protocol causing this?
    Thank you in advance!
  • 2.  RE: INSTANT Does not change channel
  • 3.  RE: INSTANT Does not change channel
    Posted Sep 02, 2016 07:50 AM
    Hi Colin, Glad to talk with you !
    I follow as you say, this was function just right, with no problem.
    I change and relfect in secounds in the configuration.
    Dont know why is now not comunication...
    Do i have to disable ARM in general?
  • 4.  RE: INSTANT Does not change channel
    Posted Sep 02, 2016 08:50 AM
    You typically have to reboot that access point to have the static channel be applied.  I thought that as of 4.2.x.x you didn't have to do that, but reboot the AP, to see if the static channel "sticks".
  • 5.  RE: INSTANT Does not change channel
    Posted Sep 02, 2016 09:11 AM
    Thank you for your support, i have to schedule a downtime with the client.
    Best Regards
    Bruno
