Instant does not redirect to Clearpass
  • 1.  Instant does not redirect to Clearpass
    Posted Sep 08, 2014 10:57 PM
    Tried a few different clients/browsers and no-one gets redirected to the captive portal URL.
    You can type in the URL and go there directly though and login no problem, so fairly confident the Clearpass side is correct. Going to any other URL directly results in a blank page. Users have correct role 'guest-login' in Instant.
    Pretty basic setup so not at all clear why this is not working.
    wlan access-rule "Guest"
    index 3
    captive-portal external profile "Guest"
    rule any any match any any any deny
    wlan access-rule guest-guest
    index 4
    rule any any match any any any permit log
    wlan access-rule guest-presenter
    index 5
    wlan access-rule guest-contractor
    index 6
    wlan access-rule guest-login
    index 7
    wlan ssid-profile "Guest"
    enable
    index 1
    type guest
    essid "Guest"
    opmode opensystem
    max-authentication-failures 0
    vlan guest
    auth-server clearpass
    set-role-pre-auth guest-login
    set-role Aruba-User-Role value-of
    rf-band all
    mac-authentication
    dtim-period 1
    inactivity-timeout 1000
    broadcast-filter arp
    radius-reauth-interval 60
    radius-accounting
    radius-interim-accounting-interval 60
    dmo-channel-utilization-threshold 90
    local-probe-req-thresh 0
    max-clients-threshold 64
    wlan auth-server clearpass
    ip 10.1.22.9
    port 1812
    acctport 1813
    key <snip>
    rfc3576
    cppm-rfc3576-port 5999
    wlan external-captive-portal "Guest"
    server clearpass.<snip>.com
    port 443
    url "clearpass.<snip>.com/guest/login.php"
    auth-text ""
    auto-whitelist-disable
    https
  • 2.  RE: Instant does not redirect to Clearpass
    Posted Sep 08, 2014 11:57 PM
    One thing you are missing is a rule allowing http/https to your clearpass server
  • 3.  RE: Instant does not redirect to Clearpass
    Posted Sep 09, 2014 12:25 AM
    So added these rules and no change...can go direct but no redirect on any browser/platform.
    Even weirder traffic is disregarding these rules anyway and being let straight through..
    Sep 9 14:22:12 10.1.22.43 stm[1529]: <124006> <WARN> <10.1.22.43 24:DE:C6:C3:ED:3E> TCP srcip=172.31.98.3 srcport=60611 dstip=74.125.31.95 dstport=443, action=src-nat
    Sep 9 14:22:12 10.1.22.43 stm[1529]: <124006> <WARN> <10.1.22.43 24:DE:C6:C3:ED:3E> TCP srcip=172.31.98.3 srcport=44743 dstip=173.194.72.95 dstport=443, action=src-nat
    But the page still can't load. These logs are from a client with the guest-login role:
    index 7
    rule any any match udp 67 68 permit log
    rule any any match udp 53 53 permit log
    rule 10.1.22.9 255.255.255.255 match any any any permit log
    rule any any match any any any deny log
  • 4.  RE: Instant does not redirect to Clearpass
    Posted Sep 09, 2014 05:57 AM
    And took 5 minutes to prove the clearpass config was correct with an ArubaOS version of the SSID. Instant fails to live up to it's name again.
  • 5.  RE: Instant does not redirect to Clearpass
    Posted Sep 09, 2014 06:36 AM
    In your config for the captive portal, for the url I believe you only need this, not the full path.
    url /guest/login.php
  • 6.  RE: Instant does not redirect to Clearpass
    Posted Sep 09, 2014 08:27 PM
    Ah that was it.
    Total misuse of the term URL and this is the doco for it with no examples:
    "URL Enter the URL for the external captive portal server."
    Frustrating to find time wasters like this.
