Instant Errors diagnostics
  • 1.  Instant Errors diagnostics
    Posted Aug 06, 2015 09:12 AM
    Hi everyone.
    I want to know how to avoid the errors on IAP-103
    Some users seem to have problems with connection. Low speed, etc.
    Aruba Central graph shows errors on 5GHz channel:
    RF channel utilization
    The other graphs don't seem to be useful.
    What is the critical error level?
    What is the nature of this errors?
    How can I avoid them?
  • 2.  RE: Instant Errors diagnostics
    Posted Aug 06, 2015 09:17 AM
    Please open up a case to dive deeper into these errors.
  • 3.  RE: Instant Errors diagnostics
    Posted Aug 06, 2015 09:33 AM
    Simple Instant cluster without controller: IAP-103, 105, 205
    This graphs are from IAP-103
    It is located in the office room.
    ~10 5GHz clients
    ~10 2.4 GHz clients
    Devices: iphone, ipad, macbook air, macbook pro
    The 5GHz range is not very busy: 3 IAPs and 1 asus router there.
    2 ssid's: for notebooks and for mobile devices.
  • 4.  RE: Instant Errors diagnostics
    Posted Aug 06, 2015 11:29 AM
    I've found that all of IAPs had error peak at the same time on the August 5th.
    All ranges were affected. How to diagnose this problem?
    IAP-103 2.4GHz
    IAP-103 5GHz
    IAP-105 2.4GHz
    IAP-105 5GHz
    IAP-205 2.4GHz
    IAP-205 5GHz
  • 5.  RE: Instant Errors diagnostics
    Posted Aug 06, 2015 12:01 PM
    Hmm. The situation is strange.
    The wireless clients graph shows that it was ~400 clients at the peak moment. But I don't really think it was. There was aruba central disconnect at that time. Maybe it's just a bug?
    And what's the difference between clients and wireless clients?
