Instant firmware upgrade issue
  • 1.  Instant firmware upgrade issue
    Posted Jul 22, 2017 10:24 AM
    My IAP 305s are running with firmware 6.5.1.0-4.3.1.0_57768. The latest version available is 6.5.2.0. I tried to upgrade the firmware manually but got the error "Invalid Image File".
    Then I tried "Automatic" and it said there is "-- No new version available --".
    Next I tried the debug-download command and was able to successfully connected to the image server but the images are not available(I tried two version).
    The firmware filename is ArubaInstant_Vela_6.5.2.0_59123
  • 2.  RE: Instant firmware upgrade issue
    Posted Jul 22, 2017 10:28 AM
    For the 305 it should be Ursa.
    Please see the limited lifetime warranty upgrade page here:  http://support.arubanetworks.com/LifetimeWarrantySoftware/tabid/121/DMXModule/661/EntryId/25165/Default.aspx
  • 3.  RE: Instant firmware upgrade issue
    Posted Jul 22, 2017 10:42 AM
    Thanks. Do you know why my support page only have Vela?
    Another question: are the MIB file the same? or there is a Ursa version of MIB?
  • 4.  RE: Instant firmware upgrade issue
    Posted Jul 22, 2017 02:45 PM
    Mib files are the same across all models.
    What is the URL of your support page?
  • 5.  RE: Instant firmware upgrade issue
    Posted Jul 24, 2017 02:13 PM
    HPE Support -> My Networking Portal
    I clicked one of my registered 305 AIP and it took me to the firmware page contains only Velsa firmware...
  • 6.  RE: Instant firmware upgrade issue
    Posted Jul 24, 2017 04:31 PM
    If you could paste in the URL, and a screenshot, that would be good.  Meanwhile, please use the URL that I posted above...
