Instant (IAP) downloadable user role (DUR) with vlan argument not downloaded
  • 1.  Instant (IAP) downloadable user role (DUR) with vlan argument not downloaded
    Posted Jul 08, 2020 12:33 PM
    Hello!
    I tried to apply the user vlan in combination with the user role as DUR from Clearpass to IAP.
    For this I used the type Radius:Aruba with Aruba-CPPM-Role and the value:
    wlan access-rule vl20_allow-all
    vlan 20
    rule any any match any any any permit
    This can be configured on instant cli and GUI.
    But if I deploy this as DUR, the VC won't download the role.
    I successfully pushed the role without the vlan.
    To apply the vlan, I used a second enforcement profile with the Aruba-User-Vlan Attribute.
    I found a similar described behavior at AOS here.
    Is this expected on AOS and IAP?
    Should it be as designed that vlans can not pushed with the DUR?
    Thank you!
  • 2.  RE: Instant (IAP) downloadable user role (DUR) with vlan argument not downloaded
    Posted Jul 27, 2020 05:14 AM
    For:
    • IAP/controller DUR: Send separate User-role contents and the VLAN in a separate attribute (Filter-ID/Aruba-User-VLAN/Aruba-User-VLAN-Name). BTW, Role-based VLANs are deprecated/non-supported on controllers/IAP, which may be why.
    • ArubaOS Switch DUR: Send VLAN as part of the User-Role. If you send multiple RADIUS Attributes, everything will be rejected by the switch.
  • 3.  RE: Instant (IAP) downloadable user role (DUR) with vlan argument not downloaded
    Posted Jul 27, 2020 05:25 AM
    Hello Herman!
    Thank you, sounds plausible.
