Instant IAP Guest Redirect to a Tranparent Proxy
  • 1.  Instant IAP Guest Redirect to a Tranparent Proxy
    Posted Feb 18, 2015 10:46 AM
    Hi
    I would like to re-direct guest users to a squid transparent proxy.  I have created a guest SSID and assigned a vlan 10 with controller assigned local DHCP.  The users are using the internal radius server and captive portal.
    Guests users get an IP address 172.16.1.xx (Class C).  I want to force them to 192.168.6.126 which is my transparent proxy server so they can be filtered.
    Can someone please advise of what network / user roles I need to enable this to happen.
    I have looked into esi redirect and source nat but can't work it out.
    Any help gratefully recieved.
  • 2.  RE: Instant IAP Guest Redirect to a Tranparent Proxy
    Posted Feb 18, 2015 11:48 AM
    See if this helps you :
    http://community.arubanetworks.com/t5/Controller-less-WLANs/How-to-configure-proxy-HTTP-server-on-Aruba-Instant-AP/ta-p/175520
    If you need to be more specific within a certain ssid you can then apply this rule at the access level
