Instant Login
  • 1.  Instant Login
    Posted Feb 03, 2014 05:21 AM
    I Have just rebooted all my access points, I now can't login in to the instant web UI is says login failure.
    I am using the same username and password that I used to login to reboot the AP's.
    I have tried the default username and password!
    All my SSID still exist so the config hasn't been wiped?!?
    Any help would be appreciated.
  • 2.  RE: Instant Login
    Posted Feb 03, 2014 07:14 AM
    If you've exhausted all opportunities at remembering the password, you can reset it using a similar process to the controllers.
    Console to the Master AP.
    username = admin
    password = forgetme!
    To see the password:
    encrypt disable
    show mgmt-user
    To reset the password:
    configuration terminal
    mgmt-user admin <password>
    exit
    write memory
  • 3.  RE: Instant Login
    Posted Feb 04, 2014 01:46 AM
    I have tried the same command but still it showing the passwords in encrypted form
    (IMH-MC3600) #show mgmt-user
    Management User Table
    USER             PASSWD                                               ROLE        STATUS
    test  df48654a011cd8d92e5a8fe1b48a79c3ae50c74076f9853dec   read-only   ACTIVE
    admin            b63274d601ab5c352b2f1792805c0183a048a94524e0745aa3   root        ACTIVE
  • 4.  RE: Instant Login
    Posted Feb 04, 2014 02:37 AM
    By the wat  I tested it on controller not IAP. Please advice if its different from controller.
  • 5.  RE: Instant Login
    Posted Feb 04, 2014 04:11 AM
    For the controller, it is the same method as mentioned.
    Useranme password
    Password: forgetme!
    go to configure terminal and use mgmt-user admin root. Then follow by the passwords twice.
  • 6.  RE: Instant Login
    Posted Feb 04, 2014 04:23 AM
    I have tried on controller to view the password but it shows the password in encrypted form. I have also applied encryption disable command. See the out of post command i have pasted in my earlier post.
  • 7.  RE: Instant Login
    Posted Feb 04, 2014 04:41 AM
    You are not able to observe administrator passwords.
  • 8.  RE: Instant Login
    Posted Feb 04, 2014 05:02 AM
    Thank CJ. It is for both Instant and Controller?
  • 9.  RE: Instant Login
    Posted Feb 04, 2014 05:08 AM
    Yes.  That is a big security no-no
  • 10.  RE: Instant Login
    Posted Feb 04, 2014 05:15 AM
    yes got it. That is what I was thinking from security prospective.
    Thanks for updating
  • 11.  RE: Instant Login
    Posted Feb 04, 2014 07:38 AM
    The command to view the password only works on Instant, not the controller.   I agree with Colin however, this is a no-no and probably should be addressed on Instant.
  • 12.  RE: Instant Login
    Posted Feb 06, 2014 01:51 AM
    Thanks Clembo for the clarification. Plase do advice whether "encrypt enable" command applicable of IAP?
  • 13.  RE: Instant Login
    Posted Feb 04, 2014 04:17 AM
    Hi
    Thanks for the reply, I didn't need to do anything in the end as about 3 hours after the reboot, the 11A/N and 11B/G/N lights on the APs went red  and then 30 mins later went back to green. I could then login to the web UI again using the correct password.
    Cheers
  • 14.  RE: Instant Login
    Posted Feb 06, 2014 02:25 AM
    @mvtown wrote:
    Hi
    Cheers
    Your IAPs probably booted up in mesh mode.  This can happen due to no ethernet link or the inability to get an IP address/DHCP issues.  When it's in mesh mode, you cannot login to the AP.  It doesn't tell you why it fails, but it just fails.  I guess this is for security reasons (?) but makes it difficult to do any troubleshooting since you can't login to run commands, tech-support, etc.
