Instant Mesh WPA3
  • 1.  Instant Mesh WPA3
    Posted Nov 20, 2020 03:32 AM
    setting up MESH it's only possible to use WPA2 - any plans to support WPA3 for mesh in near future ?
    BR
    Jochem
    Jochem Knoben
  • 2.  RE: Instant Mesh WPA3
    Posted Nov 23, 2020 04:56 AM
    I have not heard about such a feature. To be honest, with the long and random passphrase that mesh uses, the risk should be overseeable, but the ask is fair.
    Can you have your Aruba partner (or yourself if you have access) or Aruba SE file a request for that in Aruba Innovation Zone?
    If you have urgent issues, always contact your Aruba partner, distributor or Aruba TAC Support. Check https://www.arubanetworks.com/support-services/contact-support/ for how to contact Aruba TAC.
  • 3.  RE: Instant Mesh WPA3
    Posted Nov 23, 2020 06:36 AM
    Hi Herman,
    thanx for the fast reply.
    I opened: Idea WLAN-I-1633
    In case someone wants to support this request, pls. vote for it.....
    Jochem Knoben
