Instant mode with 2 level of backup
  • 1.  Instant mode with 2 level of backup
    Posted Feb 14, 2014 05:11 AM
    Hi!
    I've got question. In attachment there is topology of 2 level backup. Is there any possibility to configure Aruba Instant like that?
    Thanks in advance!
    Attachment(s)
    pptx
    Internet_link_backup.pptx   598 KB 1 version
  • 2.  RE: Instant mode with 2 level of backup
    Posted Feb 14, 2014 08:12 AM
    The only issue there is that the RAP3 won't be able to do a mesh connection since those only support 2.4Ghz and the mesh link is built using the 5Ghz band .
    You can potentially try having an IAP105(Virtual Controller)  configured the wired profile as an uplink and connect it to one of ports of the RAP3  and that IAP105 will make the mesh connection back to the other IAP105.
    Hope it make sense
  • 3.  RE: Instant mode with 2 level of backup
    Posted Feb 14, 2014 08:24 AM
    Thank you so much!
