Instant-On AP 12: Can't find firmware
  • 1.  Instant-On AP 12: Can't find firmware
    Posted Feb 13, 2020 04:39 AM
    I'm sorry, all.  But navigating through this community.arubanetworks.com and asp.arubanetworks.com is both a challenge and an art.
    I've bought a few AP 12 model units (click here to see what I'm talking about) and am taking them to a site that won't have internet connectivity.
    I really need to figure out where to look, and from where to download, the firmware they will need.
    I believe it's Orion 6.x.x (click here for the page) but the AP12 is not listed as compatible.
    Guidance, please, and thanks.
  • 2.  RE: Instant-On AP 12: Can't find firmware
    Posted Feb 13, 2020 05:25 AM
    Part number from the above pages means this AP12 is also known as:
    R2X01A
  • 3.  RE: Instant-On AP 12: Can't find firmware
    Posted Feb 13, 2020 05:40 AM
    Once I find the file, I can then follow the instructions here:
    Upgrade procedure
  • 4.  RE: Instant-On AP 12: Can't find firmware
    Posted Feb 13, 2020 01:48 PM
    50 views, still no answer, I'm starting to think there are over 40+ other individuals with the same issue.  I truly cannot find it.  Thanks all for looking thusfar.
  • 5.  RE: Instant-On AP 12: Can't find firmware
    Posted Feb 13, 2020 02:52 PM
    The Instant Access Points(IAPs) are different from the Instant-on APs. There is also a community dedicated to the Instant-on APs (here) Your question may be better suited for that forum.
    That being said, I don't believe there is a way to manually upgrade the firmware on the Instant-On series without having internet access, as they download it from a cloud server. More information can be found here
    (Full disclosure, I don't have personal experience with the AP-12, I just wanted to give you more paths to investigate)
  • 6.  RE: Instant-On AP 12: Can't find firmware
    Posted Feb 21, 2020 05:10 AM
    You, good sir of my former stomping grounds (Northampton County, PA) were spot-on.  Guess I'll schlep on over that way.  Thanks!
