Instant Re-Authentication - User Role
  • 1.  Instant Re-Authentication - User Role
    Posted Aug 22, 2018 12:29 PM
    Any way to set a re-authentication interval either from Clearpass enforcement or by specifying it on the Instant User Role?
    I tried passing radius:ietf / session-timout / 60 (for 60 second re-auth as a test) and the Cluster seems to ignore this.
  • 2.  RE: Instant Re-Authentication - User Role
    Posted Aug 22, 2018 01:03 PM
    This is only useful for a Captive Portal setup, by the way.  If you force a 802.1x client to reauthenticate, the supplicant will resubmit the credentials and the client will simply reattach.
    https://www.arubanetworks.com/techdocs/Instant_423_WebHelp/InstantWebHelp.htm#CLI_commands/wlan%20ssid-profile.htm?Highlight=reauth%20interval
  • 3.  RE: Instant Re-Authentication - User Role
    Posted Aug 22, 2018 01:08 PM
    So it looks like it is only do-able on the WLAN itself. I guess I will make due with that. There will be other devices connected that I dont really want to re-auth (Some IOT devices using device profiling to bypass cap portal) but they should be OK with it.
    Yes, this is for Captive Portal.
    Thanks for the response!
  • 4.  RE: Instant Re-Authentication - User Role
    Posted Aug 22, 2018 01:09 PM
    To check to see if the session-timeout attribute is being adhered to, use the
    "show client debug" command and look for the session-timeout for that user:
    http://community.arubanetworks.com/t5/Controller-less-WLANs/How-to-configure-the-Radius-session-timeout-with-Aruba-Instant/ta-p/178718
  • 5.  RE: Instant Re-Authentication - User Role
    Posted Aug 22, 2018 01:28 PM
    Thanks! That got me going in the right direction. The Radius:IETF Session-Timout does work. I was sending it twice and the longer duration trumped the shorter duration hence why I was not seeing a re-auth.
    FYI - I dont think newer IAP code shows the session time-out any longer. I am running 6.5.4.6. It is hard to read the blob of data but I dont think I see the timeout. Anyway, thanks for the help guys!
  • 6.  RE: Instant Re-Authentication - User Role
    Posted Aug 22, 2018 01:32 PM
    Decrease your font, or view the output on a wide monitor.
