Instant RF Zones
  • 1.  Instant RF Zones
    Posted Feb 16, 2020 11:27 AM
    Hi, I'm trying to identify within the sh run output in what line it is defined which AP is assigned to which RF zone, but I just compared the sh run ouptuts with and without RF zone assignment and they look the same.
    Could it be that I need to see into a different config output?
  • 2.  RE: Instant RF Zones
    Posted Feb 17, 2020 03:31 AM
    Have you tried the show radio profile command? The active profile of an AP is listed in the Zone column.
  • 3.  RE: Instant RF Zones
    Posted Feb 17, 2020 09:14 AM
    Yes, it is seen there, but what catches my attention is that nothing seems to be displayed about it in sh run, I'd think that this command shows everything regarding the configuration.
  • 4.  RE: Instant RF Zones
    Posted Feb 17, 2020 10:58 AM
    Though RF Zone is a config, it is applied to individual IAP's.
    You can run 'show ap-env' to see if the zone is applied or not.
    IAP-324# show ap-env
    Antenna Type:External
    Need USB field:Yes
    a_ant_gain_10x:50.0
    standalone_mode:1
    uap_controller_less:1
    iap_rf_zone:new5
  • 5.  RE: Instant RF Zones
    Posted Feb 17, 2020 11:08 AM
    Thank you for your reply, this command's output is the information I was looking for.
    Just curious, do you know if there is a command that shows more information about each AP's own settings?
    Regards
  • 6.  RE: Instant RF Zones
    Posted Feb 17, 2020 11:22 AM
    'show ap-env' has to be run for individual IAP's and this shows the ap-specific config. Alternatively, use the WebUI and choose 'AP Environment Details' and run it against the IAP(s).
    Rest of the configuration will be same/common for the IAP's.
    To view much detailed info, run 'show tech-support' on each of the IAP's for which you need the details.
  • 7.  RE: Instant RF Zones
    Posted Feb 17, 2020 11:24 AM
    Thank you, this will be very useful.
