  • 1.  Instant SSID
    Posted May 11, 2015 10:24 PM
    Dear Support,
    I would like to ask is that only the "instant" SSID will appear for a new IAP if the IAP can get the ip address by DHCP?
    Alvin.
  • 2.  RE: Instant SSID
    Posted May 11, 2015 11:17 PM
    No. It will appear if there is no configuration.
    Tim
  • 3.  RE: Instant SSID
    Posted May 11, 2015 11:47 PM
    Hi Tim
    But I have a IAP 135, I have just factory reset it but it keep reboot and the "instant" SSID  didnt appear.
    any idea?
    Alvin.
  • 4.  RE: Instant SSID
    Posted May 12, 2015 03:02 AM
    depends on the version you are ruining. if an older firmware you require a dhcp address to the IAP in order to broadcast instant.
  • 5.  RE: Instant SSID
    Posted May 12, 2015 03:22 AM
    I am using 6.4.0.3-4.1.0.1
    Partition 1:
    image type: 0
    machine type: 15
    version: 6.4.0.3-4.1.0.1
    build string: ArubaOS version 6.4.0.3-4.1.0.1 for Cassiopeia (p4build@cyprus) (gcc version 4.3.3) #45063 Sun Jul 27 19:57:01 PDT 2014
    flags: Instant preserve
    Image is signed; verifying checksum... passed
    Signer Cert OK
    Policy Cert OK
    RSA signature verified.
    baudrate=9600
    autoload=n
    boardname=Arran
    servername=aruba-master
    bootcmd=boot ap
    autostart=yes
    bootfile=armv5te.ari
    ethaddr=24:de:c6:c9:19:80
    "os_partition=1"
    stdin=serial
    stdout=serial
    stderr=serial
    ethact=eth0
    Is it normal for this version?
    Many thanks
  • 6.  RE: Instant SSID
    Posted May 12, 2015 03:32 AM
    This is the startup config but I think this is the default one, since I didnt change the config after factory reset
    version 6.4.0.0-4.1.0
    virtual-controller-key 8f843db7011c2df8703eb94864919d0b92d40f7b42232ebeaf
    name instant-C9:19:80
    terminal-access
    clock timezone none 00 00
    rf-band all
    allow-new-aps
    allowed-ap 24:de:c6:c9:19:80
    arm
    wide-bands 5ghz
    80mhz-support
    min-tx-power 18
    max-tx-power 127
    band-steering-mode prefer-5ghz
    air-time-fairness-mode fair-access
    client-aware
    scanning
    syslog-level warn ap-debug
    syslog-level warn network
    syslog-level warn security
    syslog-level warn system
    syslog-level warn user
    syslog-level warn user-debug
    syslog-level warn wireless
    extended-ssid
    mgmt-user admin 09fed2405d9a6ed30cc5869272977010
    wlan access-rule instant
    index 0
    rule masterip 0.0.0.0 match tcp 80 80 permit
    rule masterip 0.0.0.0 match tcp 4343 4343 permit
    rule any any match udp 67 68 permit
    rule any any match udp 53 53 permit
    wlan access-rule default_wired_port_profile
    index 1
    rule any any match any any any permit
    wlan access-rule wired-instant
    index 2
    wlan ssid-profile instant
    enable
    index 0
    type employee
    essid instant
    opmode opensystem
    max-authentication-failures 0
    vlan guest
    rf-band 2.4
    captive-portal disable
    dtim-period 1
    inactivity-timeout 1000
    broadcast-filter none
    dmo-channel-utilization-threshold 90
    local-probe-req-thresh 0
    max-clients-threshold 64
    auth-survivability cache-time-out 24
    wlan external-captive-portal
    server localhost
    port 80
    url "/"
    auth-text "Authenticated"
    auto-whitelist-disable
    https
    blacklist-time 3600
    auth-failure-blacklist-time 3600
    ids classification
    ids
    wireless-containment none
    wired-port-profile wired-instant
    switchport-mode access
    allowed-vlan all
    native-vlan guest
    no shutdown
    access-rule-name wired-instant
    speed auto
    duplex auto
    no poe
    type guest
    no dot1x
    wired-port-profile default_wired_port_profile
    switchport-mode trunk
    allowed-vlan all
    native-vlan 1
    shutdown
    access-rule-name default_wired_port_profile
    speed auto
    duplex full
    no poe
    type employee
    no dot1x
    enet0-port-profile default_wired_port_profile
    uplink
    preemption
    enforce none
    failover-internet-pkt-lost-cnt 10
    failover-internet-pkt-send-freq 30
    failover-vpn-timeout 180
    airgroup
    disable
    airgroupservice airplay
    disable
    description AirPlay
    airgroupservice airprint
    disable
    description AirPrint
  • 7.  RE: Instant SSID
    Posted May 12, 2015 05:42 AM
    Hi
    I power up the AP with POE injector and not connect to any switch, and keep looking the AP by console.
    I have tried to config the ip addr, netmask,  gateway at bootup
    but "Instant" SSID still not appear and the AP keep reboot...
    can someone help me @@
    Many Thanks
  • 8.  RE: Instant SSID
    Posted May 12, 2015 05:54 AM
    Are you trying to do a survey?  Configure the option in the picture below:
    http://www.arubanetworks.com/techdocs/Instant_41_WebHelp/InstantWebHelp.htm#CLI_commands/wlan ssid-profile.htm
  • 9.  RE: Instant SSID
    Posted May 17, 2015 07:09 PM
    hi,
    the instant SSID disapear once you create an other SSID.
    any way, since you can't get the Instant SSID  , you can connect your IAP to the network (with the DHCP),
    once it boot ,connect to it using serial cable,  get the IAP IP adresse using "show ip int brief" commande, then use this adresse to access via the the browser, you can create an SSID and test it.
  • 10.  RE: Instant SSID
    Posted May 17, 2015 07:10 PM
    what was the contry code that you have issued the very first time ?!
    the issue may be caused by the regulatory domain , if this AP is not registred in your country.
