instant ssid
  • 1.  instant ssid
    Posted Sep 16, 2018 09:21 AM
    Hi Aruba experts,
    I am new to aruba. we have 10 305 IAP. 8 are connecting to the controller fine while 2 are not. LEDs on both are blinking green and they are transmitting "INSTANT" ssid. I can connect to that ssid and login into the instant web gui where i can see the 2 APs. Kindly help me how to connect these 2 APs to the aruba controller like the other 8 APs. Thanks.
  • 2.  RE: instant ssid
    Posted Sep 16, 2018 10:02 AM
    SSH into the AP that is not joining and type "show log system" to see if you can understand what is happening.
    There is a video (13 minutes) about troubleshooting instant IAPs not being able to join the cluster here:  http://community.arubanetworks.com/t5/Video/VIDEO-Common-Issues-with-Instant-Access-Point-IAP-Not-Joining/ta-p/90318
  • 3.  RE: instant ssid
    Posted Sep 16, 2018 10:50 AM
    Thanks. I will check it tomorrow morning but plz tell me if there is something as convert to campus ap. We are using 7024 controller. May be this iap was factory reset.
  • 4.  RE: instant ssid
    Posted Sep 16, 2018 10:51 AM
    "plz tell me if there is something as convert to campus ap."
    What do you mean?
    EDIT:  Yes, you can convert an Instant AP to a Campus AP.  Please search the documentation here:  https://www.arubanetworks.com/techdocs/Instant_83_WebHelp/Web_Help_Index.htm
