Instant SSIDs not active
  • 1.  Instant SSIDs not active
    Posted Jul 23, 2017 09:29 PM
    hi,
    i have a number of working SSIDs in my Instant cluster. recently, we have tried adding a few new SSIDs & none of them are working. after some digging, i noticed that although disable is unchecked, these SSIDs still show "no" under Active status.
    i cant find on these forums or elsewhere a way to change their active status to "yes".
    any advice would be much appreciated.
  • 2.  RE: Instant SSIDs not active
    Posted Jul 23, 2017 10:03 PM
    What model IAP?
    What regulatory domain?
    What version of Instant software?
  • 3.  RE: Instant SSIDs not active
    Posted Jul 23, 2017 10:06 PM
    Sorry for not posting in initial post
    i have iap 105s, in USA.
    Instant version is 6.4.4.8-4.2.4.6_58505
  • 4.  RE: Instant SSIDs not active
    Posted Jul 23, 2017 10:08 PM
    The post here:  http://www.arubanetworks.com/techdocs/Instant_423_WebHelp/InstantWebHelp.htm#UG_files/WLAN_SSID_conf/SSIDEnableDisable.htm%3FTocPath%3DUG%2520topics%7CWireless%2520Network%2520Profiles%7C_____6 should tell you how to enable or disable SSIDs.
    I don't see a problem with your combination of code, domain or IAP model.
  • 5.  RE: Instant SSIDs not active
    Posted Jul 23, 2017 10:22 PM
    As i wrote in the original post, the SSIDs are showing up as "enabled" but "active" is still showing as "no".
    the above post wont help me. i already tried disabling & reenabling but status still stays as not active.
    thanks
  • 6.  RE: Instant SSIDs not active
    Posted Jul 23, 2017 10:27 PM
    here is a screenshot of show network where you can see what i am referring to
  • 7.  RE: Instant SSIDs not active
    Posted Jul 23, 2017 10:33 PM
    By default SSIDs should not be disabled except maybe for regulatory reasons.  Is this a US IAP or a ROW or IL IAP?
    Did your IAPs even broadcast the instant SSID?
  • 8.  RE: Instant SSIDs not active
    Posted Jul 23, 2017 11:10 PM
    I have a number of SSIDs broadcasting properly.
    these are US IAPs.
    When i first setup the system a few years ago, the instant SSID was broadcast.
  • 9.  RE: Instant SSIDs not active
    Posted Aug 02, 2017 05:10 PM
    Just to put the solution out. i ended up contacting support & after they looked into it further, my model (IAP105) only supports 6 SSIDs. We had to delete a few SSIDs & enable "Extended SSID" to allow 8 SSIDs.
    once we got that properly set, my new SSIDs became active.
    Hope this will help anyone else that runs into this issue.
