instant - syslog server configuration
  • 1.  instant - syslog server configuration
    Posted Jun 10, 2015 10:36 AM
    I would like to capture and log information about which web pages AP clients visited. Additional I would like to keep this infromations for 2 years. Is it possible to do it using Syslog server and IAP?
    Thanks in advance!
    Mathew
  • 2.  RE: instant - syslog server configuration
    Posted Jun 10, 2015 05:40 PM
    The closest I can see getting from the iAP proper would by to turn on logging on the intersting ACLs in the ACL for your users' role. You'll likely get the IP address of the destination though and have to work out the site and/or URL on your own.
    If you want to know site names and URLs etc, you'll want to monitor the traffic upstream with a proxy or sniffer etc.
