Instant TACACS+ management roles possible?
  • 1.  Instant TACACS+ management roles possible?
    Posted Jun 23, 2015 10:32 AM
    Dear all,
    I try to configure the TACACS+ authentication for Instant controllers.
    Basically it works, but is there a way how I can use different access roles for the users?
    I need normally an admin role and something like a "monitor" for read only.
    Is that possible? Or if it is not with TACACS+, is it possible with RADIUS?
    Thanks a lot!
    Sven
  • 2.  RE: Instant TACACS+ management roles possible?
    Posted Jun 23, 2015 10:37 AM
    Are you using clearpass as a tacacs server ?
  • 3.  RE: Instant TACACS+ management roles possible?
    Posted Jun 23, 2015 11:08 AM
    No, we are using the Cisco ACS 4.x and in future 5.x.
    Can you describe how I have to configure that? Is there something I have to add in the instant controller or on the TACACS+ server?
  • 4.  RE: Instant TACACS+ management roles possible?
    Posted Jun 30, 2015 03:21 PM
    this seems to indicate it is not possible to assign different roles
    http://community.arubanetworks.com/t5/AAA-NAC-Guest-Access-BYOD/How-to-authenticate-IAP-admin-user-against-CPPM-over-TACACS/ta-p/192931
    you might experiment with level 0 or 1 and see what that does.
  • 5.  RE: Instant TACACS+ management roles possible?
    Posted Jul 01, 2015 03:17 AM
    Thank you very much for the link.
    So it seems that this is not working.
    Is it possible to assign different roles with RADIUS?
  • 6.  RE: Instant TACACS+ management roles possible?
    Posted Aug 03, 2015 11:13 AM
    Management roles for TACACS+ and RADIUS will be added in Instant 4.2 which will be released in the coming weeks.
  • 7.  RE: Instant TACACS+ management roles possible?
    Posted Jun 23, 2015 10:38 AM
  • 8.  RE: Instant TACACS+ management roles possible?
    Posted Jun 23, 2015 10:39 AM
    Hi friend,
    It is absolutely possible :)
    Please feel free for any further help on this.
