Instant Upgrade to ArubaInstant_Orion_6.3.1.1-4.0.0
  • 1.  Instant Upgrade to ArubaInstant_Orion_6.3.1.1-4.0.0
    Posted Jan 05, 2014 12:33 AM
    Hi everyone,
    Lately I have tried upgrade Instant APs to the latest version ArubaInstant_Orion_6.3.1.1-4.0.0 but I faced an issue as all radio LEDs turned red and no SSIDs are advertised.
    I am not sure if this is an issue with the OS it self but rolling back to the earlier version 6.2.0.0 seems to solve the problem.
  • 2.  RE: Instant Upgrade to ArubaInstant_Orion_6.3.1.1-4.0.0
    Posted Jan 05, 2014 12:34 AM
    What is your regulatory domain?
  • 3.  RE: Instant Upgrade to ArubaInstant_Orion_6.3.1.1-4.0.0
    Posted Jan 05, 2014 12:35 AM
    I think it's KW as in Kuwait. [Mod note: removed spoiler formatting]
  • 4.  RE: Instant Upgrade to ArubaInstant_Orion_6.3.1.1-4.0.0
    Posted Jan 05, 2014 12:52 AM
    red? the lighs on the bgn and an should be green or orange.
    If they are orange after the upgrade its beacuse of the regulatory domain.
    You have to change it to something like cananda
    Check this out
    http://community.arubanetworks.com/t5/Unified-Wired-Wireless-Access/List-of-Regional-Domains-where-the-AP-works/td-p/112535
    Also check the regulatory compliance
    Look for your country and the AP you using
    https://pctools.arubanetworks.com/compliance/
    If you see that your ap is not listed for your country, then that should be the issue... and thats why you need to change the coutnry to code to something liek cananda
    Cheers
    Carlos
