Instant url ftp upgrade
  • 1.  Instant url ftp upgrade
    Posted May 04, 2016 08:29 AM
    Is it possible to use the ftp url with username and password for upgrade instant cluster? For example:
    ftp://username:password@<ftp_ip_address>:21/backup/ArubaInstant_Orion_6.4.4.4-4.2.3.1_54637
    Thanks & best regards,
    Jan Masin.
  • 2.  RE: Instant url ftp upgrade
  • 3.  RE: Instant url ftp upgrade
    Posted May 04, 2016 09:09 AM
    Dear Victor,
    Thank you for fast reply.
    I know this link, but I don't see the syntax for url ftp with username and password. If I enter this:
    ftp://username:password@<ftp_ip_address>:21/backup/ArubaInstant_Orion_6.4.4.4-4.2.3.1_54637 then instant returns this error:
    Executing '/aruba/bin/download_image_swarm ftp://username:password --no-proxy X-Ap-Info:BT0792202,9c:1c:12:c8:a9:f0,AP-105'
    fetching ('/usr/sbin/wget -T 120 -t 3 --no-proxy --header=X-Ap-Info:BT0792202,9c:1c:12:c8:a9:f0,AP-105 -a /tmp/download_url_log ftp://username:password/ftp://username:password')
    ftp://username:password/ftp://username:password: Bad port number.
    Error: failed to retrieve image
    cleaning up
    done
    Do you know to correct syntax?
    Jan Masin.
  • 4.  RE: Instant url ftp upgrade
    Posted May 04, 2016 11:53 PM
    FTP upgrades only using anonymous credential are supported. upgrade via username password are not yet possible.
    check show log upgrade for details.
  • 5.  RE: Instant url ftp upgrade
    Posted May 05, 2016 02:37 AM
    Thank you.
    Have a nice day
