Instant VC Cluster Admin Password Reset
  • 1.  Instant VC Cluster Admin Password Reset
    Posted Oct 13, 2016 03:58 PM
    I have a cluster of IAP325's and have lost access to the GUI via  admin \ admin.  I followed a couple of posts and went to the VC, consoled in and tried to log in as admin \ forgetme! as well as password \ forgetme!.  Neither worked.  Does anyone have another suggestion as to how to gain access?  Can I cahnge it via AirWave?
    Thanks in advance for any help
  • 2.  RE: Instant VC Cluster Admin Password Reset
    Posted Oct 13, 2016 05:46 PM
    Are you using Airwave to manage the configuration on that cluster?
  • 3.  RE: Instant VC Cluster Admin Password Reset
    Posted Oct 14, 2016 08:37 AM
    I went into AirWave this morning and turned on the GUI interface for instant.  I set the password there and then turned theGUI off for local admin.  That worked.  thanks for the thought process...
  • 4.  RE: Instant VC Cluster Admin Password Reset
    MVP EXPERT
    Posted Oct 17, 2016 11:23 AM
    Ignore - Apologies
