Instant VC Config
  • 1.  Instant VC Config
    Posted Jul 01, 2016 01:08 PM
    I am getting a little confused with a new IAP install I am working on. I have configured one of my IAP as the master and configed the VC IP address, however the IAP I chose for the VC is never actually the master. All others APs have the Master option disabled.
    Any thoughts?
  • 2.  RE: Instant VC Config
    Posted Jul 01, 2016 01:10 PM
    When you say the one you chose as the master, do  you mean you set it as the preferred master?  http://www.arubanetworks.com/techdocs/Instant_41_Mobile/Advanced/Content/UG_files/CustomizeIAPParams/Master_Election_Protocol.htm
  • 3.  RE: Instant VC Config
    Posted Jul 01, 2016 01:11 PM
    Yes I configured it as the preferred master.
  • 4.  RE: Instant VC Config
    Posted Jul 01, 2016 02:34 PM
    The AP that is the VC at the time should have the asterisk right after its name.  Are you saying that this is not the case after setting it to the preferred master?
  • 5.  RE: Instant VC Config
    Posted Jul 01, 2016 02:41 PM
    Yes see the screenshots.
  • 6.  RE: Instant VC Config
    Posted Jul 01, 2016 03:11 PM
    I would run:
    (Instant AP)# show election statistics
    (Instant AP)# show summary support
    On both of those APs commandline to determine what is going on.
    Also collect "show log system" from both APs (1 and 7).
