Instant Virtual Controller support for admin banner
This thread has been viewed 19 times
  • 1.  Instant Virtual Controller support for admin banner
    Posted Sep 03, 2014 01:51 PM
    Does Aruba Instant(virtual controller) not support the posting of an admin banner?
    If so, any idea if this feature will be added? Its seems to be a standard requirment for most IT security standards.
    Mike
  • 2.  RE: Instant Virtual Controller support for admin banner
    Posted Sep 03, 2014 02:04 PM
    This is not supported in the latest code.
  • 3.  RE: Instant Virtual Controller support for admin banner
    Posted Apr 14, 2022 04:14 PM
    Aruba Instant (virtual controller) support an admin banner on WEBGUI ?.
    dauphin stephane
  • 4.  RE: Instant Virtual Controller support for admin banner
    Posted Apr 14, 2022 06:47 PM
    you can configure text banner to be displayed at the login prompt when users are on a mgmt SSH session of the CLI. But i don't think there is support for WebUI
