InstantOS for AP-325
This thread has been viewed 66 times
  • 1.  InstantOS for AP-325
    Posted Jun 07, 2023 11:45 AM
    I am new to using Aruba WiFi AP and I am considering buying a used Aruba HP AP-325 from eBay.
    I have been reading a bit about this AP supporting InstantOS.
    From what I understand is that with this firmware a setup of 325 APs can work in a cluster without the need
    of a controller, similar to Ruckus Unleashed firmware that I am familiar with.
    I would sincerely appreciate it if the community can guide me on where to find the latest InstantOS firmware image for the AP-365
    and the installation steps.
    Thanks so much _()_
    ArunK
  • 2.  RE: InstantOS for AP-325
    Posted Jun 07, 2023 06:42 PM
    with older APs such as AP-325s, you need a IAP-325 to be ale to run Instant AP firmware which does not require controller.
    the SKU for IAP-325 is JW325A which is for rest of the world (not to be used in US, Japan, Israel)
    You can download the lifetime warranty firmware without a login. In order to do that, search for 'factory image' on ASP: https://asp.arubanetworks.com/downloads;search=factory;products=Aruba%20Access%20Points
  • 3.  RE: InstantOS for AP-325
    Posted Jun 08, 2023 05:28 PM
    Thanks for the guidance.
    Per the screenshot below from link
    Would this  Instant OS firmware be the latest for IAP-325?
    Please confirm.
    Thanks so much.
    ArunK
  • 4.  RE: InstantOS for AP-325
    Posted Jun 11, 2023 06:06 PM
    looks like it
  • 5.  RE: InstantOS for AP-325
    Posted Jun 15, 2023 09:37 AM
    Hello! I'm new too)). How can I download  the new image to AP325, if I have Aruba 7005 and WEBUI. Thanks a lot!
  • 6.  RE: InstantOS for AP-325
    Posted Jun 15, 2023 09:39 AM
    Hello! I'm new in Aruba too)) I have controller Aruba 7005 and AP-325. How can I download IAP firmware  to my AP-325 by WEB GUI? Thanks a lot
  • 7.  RE: InstantOS for AP-325
    Hello! How can I download new image to AP325 via WebUI aruba 7005 controller? Thanks a lot
  • 8.  RE: InstantOS for AP-325
    Posted Jun 15, 2023 07:27 PM
    you need to login to ASP and have a valid support contract to download firmware for the controllers.
  • 9.  RE: InstantOS for AP-325
    Posted Jun 16, 2023 12:53 PM
    Thanks.  I was able to download and update an IAP-325!
    I have discovered a later version 8.10... but I think it is available only to customers with a support contract :(
    ArunK
  • 10.  RE: InstantOS for AP-325
    Posted Jun 20, 2023 02:27 AM
    "I was able to update an IAP-325!"..... without support contract? Could you tell how?
  • 11.  RE: InstantOS for AP-325
    Posted Jun 20, 2023 03:19 AM
    The lifetime warranty does provide access to 'stable' firmware. For access to any firmware, an active support contract is needed.
  • 12.  RE: InstantOS for AP-325
    Posted Jun 21, 2023 04:20 AM
    OK. What's the problem.... Which way can I  download any image to AP-325 ?
  • 13.  RE: InstantOS for AP-325
    Posted Jun 23, 2023 01:30 AM
    For IAP-325 (Instant OS) you can log in to it's Web console and apply the firmware file as shown in screenshot below.
    ArunK
  • 14.  RE: InstantOS for AP-325
    Posted Jun 23, 2023 02:02 AM
    I have AP 325 and Aruba 7005 as controller.... ((
  • 15.  RE: InstantOS for AP-325
    Posted Jun 23, 2023 12:30 PM
    I don't have any knowledge on maintaining APs via an external controller.  This forum is for "Controllerless Networks" wherein the "administration/management"  is within the AP firmware itself example the IAP-325 that comes with InstantOS image.
    Perhaps you should look for a forum for "controller" based administration ask the question there.
    IMHO - you may get better response there.
    HTH
    ArunK
