Instant/Unified ap activate.arubanetworks.com connection problem
  • 1.  Instant/Unified ap activate.arubanetworks.com connection problem
    Posted Jan 31, 2020 07:09 AM
    Ap get an ip address and after a while broadcast instant ssid to the air. Because it fails to connect to the activate. When I check the logs;
    Jan 31 07:03:04 cli[5602]: <341004> <WARN> |AP d0:15:a6:c0:9e:96@10.3.235.10 cli| The DRT vesion in payload from Activate is 1.0_71647, DRT url is http://d2vxf1j0rhr3p0.cloudfront.net/drtfiles/reg-data-1.0_71647.dat
    Jan 31 07:05:15 cli[7721]: <341004> <WARN> |AP d0:15:a6:c0:9e:96@10.3.235.10 cli| is_factory_reset_on_running : Now swarm is : factory default status
    Jan 31 07:09:53 cli[5602]: <341004> <WARN> |AP d0:15:a6:c0:9e:96@10.3.235.10 cli| is_factory_reset_on_running : Swarm quit factory default status by : UAP_controller_less
    Jan 31 07:01:58 cli[5602]: <341004> <WARN> |AP d0:15:a6:c0:9e:96@10.3.235.10 cli| Activate failed, enabling factory SSID
    Jan 31 07:03:01 cli[5602]: <341004> <WARN> |AP d0:15:a6:c0:9e:96@10.3.235.10 cli| Sending out drt-check request to Activate
    Jan 31 07:03:04 cli[5602]: <341004> <WARN> |AP d0:15:a6:c0:9e:96@10.3.235.10 cli| Activate response for 'drt-check': new_drt='1.0_71647' payload='1.0_71647 http://d2vxf1j0rhr3p0.cloudfront.net/drtfiles/reg-data-1.0_71647.dat^M '
    ...I realized those messages. I checked the firewall, all traffic allowed and inspection etc. disabled
    Anyone have an idea about this problem?
  • 2.  RE: Instant/Unified ap activate.arubanetworks.com connection problem
    Posted Feb 05, 2020 04:49 PM
    try to configure the IAP.
    the instant SSID is displayed when the IAP is factory defaulted.
    Also update the firmware and DRT to the latest versions.
