Inteference - Coordinated Access to A Single Channel
  • 1.  Inteference - Coordinated Access to A Single Channel
    Posted Feb 23, 2016 09:31 AM
    Hello all,
    Coordinated Access to A Single Channel is used to configure all AP's with the same channel. I suppose that I need to disable ARM and use all AP's with a certain channel. If I select channel 1 and if I got an interferecen on that channel, than I have a problem, right? So why o use this option? If I use 5 AP's with the same channel: I dont get less airime for other clients?
  • 2.  RE: Inteference - Coordinated Access to A Single Channel
    Posted Feb 23, 2016 10:30 AM
    What is coordinated access to a single channel?
  • 3.  RE: Inteference - Coordinated Access to A Single Channel
    Posted Feb 23, 2016 12:10 PM
    Allows nearby APs on the same channel to share spectrum. Or I am wrong?
  • 4.  RE: Inteference - Coordinated Access to A Single Channel
    Posted Feb 23, 2016 12:14 PM
    Is this mentioned in Aruba documentation?
  • 5.  RE: Inteference - Coordinated Access to A Single Channel
    Posted Feb 23, 2016 12:19 PM
    Yes
  • 6.  RE: Inteference - Coordinated Access to A Single Channel
    Posted Feb 23, 2016 12:36 PM
    Where?
  • 7.  RE: Inteference - Coordinated Access to A Single Channel
  • 8.  RE: Inteference - Coordinated Access to A Single Channel
    Posted Feb 23, 2016 12:55 PM
    That document is from 2010.  I would only look on the Aruba website for up-to-date information.
    Please see the document here:  http://www.arubanetworks.com/assets/tg/TB_EnhancedClientMatch.pdf
  • 9.  RE: Inteference - Coordinated Access to A Single Channel
    Posted Feb 23, 2016 01:04 PM
    Thank you Colin, but I dont see any info about a single channel used on nearby AP's.
  • 10.  RE: Inteference - Coordinated Access to A Single Channel
    Posted Feb 23, 2016 01:09 PM
    That is because it does not exist today
    It is not a feature today.
  • 11.  RE: Inteference - Coordinated Access to A Single Channel
    Posted Feb 23, 2016 01:14 PM
    OK, so ARUBA doesnt recommend this option anymore. You could tell me this at the beginning and to write several posts :)
    Vulpe
  • 12.  RE: Inteference - Coordinated Access to A Single Channel
    Posted Feb 23, 2016 01:18 PM
    I apologize.
    I had to:
    - Find out  what you were talking about
    - Find out where it is documented
    - Make sure that is no longer a feature
    EDIT:
    In 2010 coordinated access to a channel was important because many devices only did b/g and there was limited channel space.  Today there is 5ghz 802.11ac with many more channels and much improved performance, so that feature is not needed like it was in 2010.
  • 13.  RE: Inteference - Coordinated Access to A Single Channel
    Posted Feb 23, 2016 01:25 PM
    Thank you Colin
