integrate between Aruba controller and asset Recovery application ,,!
  • 1.  integrate between Aruba controller and asset Recovery application ,,!
    Posted Apr 23, 2014 01:18 AM
    Dears,
    I have asset Recovery application named ( REMEDY ) need to integrate with Aruba controller to get all the AP’s information exactly the serial numbers / HW info for them. So,
    1-      What is the type of AP’s DB is it ( SQL or Oracle )
    2-      Does the communication used default port TCP # 1433
    3-      What is the table name that is serving those information on the controller.
    4-      Does I need special username / password different than the one that was used on the management accessibility.
    5-      Is there any additional configuration need to added on the controller.
    waiting for your kind support ,,:catvery-happy:
  • 2.  RE: integrate between Aruba controller and asset Recovery application ,,!
    Posted Apr 23, 2014 05:50 AM
    There is no SQL interface on the Aruba Controller.  The best way to obtain that information is using SNMP.
  • 3.  RE: integrate between Aruba controller and asset Recovery application ,,!
    Posted Apr 23, 2014 07:09 AM
    Do you have ClearPass?
