Integrating a SSID with Radius Server ( Active Directory )
  • 1.  Integrating a SSID with Radius Server ( Active Directory )
    Posted Sep 23, 2018 12:50 PM
    Hi Guys , we are using 7000 Series Controllers with Aruba 8.1 IOS . We have a requirment to create a New SSID and this SSID should be integrated with Radius Server ( Active Directory ) . As any user should be able to connect this SSID by using his AD credentials . Could any expert please guide me with the steps or with any document as i am very much new to Aruba . Hope the gurus will respond and i will get help .
    Cheers :)
    Muddy.
  • 2.  RE: Integrating a SSID with Radius Server ( Active Directory )
  • 3.  RE: Integrating a SSID with Radius Server ( Active Directory )
    Posted Sep 27, 2018 09:13 AM
    Hi Joseph ,
    Thanks a lot for your help and guideline :)
